matty h
posted on 11/2/12 at 10:13 AM |
Building gravity racer
Looking to building a gravity racer want it to a 7 replica.
Seen the MNR childrens replica but not sure they are big enough.
Or could I just down scale the locost dimensions.
Suggestions welcome.
Thanks Matty
mark chandler
posted on 11/2/12 at 11:25 AM |
Sounds like you need to cut up a wheely bin
[Edited on 11/2/12 by mark chandler]
Chippy
posted on 11/2/12 at 03:42 PM |
The only thing that I know about gravity racers is they need to be as light as possable, (feather weight), and have the thinest tyres you can get,
(really thin). Not much help but thats as far as my knowledge goes. HTH Ray
MikeR
posted on 11/2/12 at 05:38 PM |
is it to compete or have fun. If its competition, see above. If fun you could probably make it out of plywood.
scotty g
posted on 12/2/12 at 10:18 AM |
In my experience the exact opposite is true, you need it to be as close to the maximum weight allowed, the heavier it is the more mass for gravity to
pull on!
A friend of mine built one a few years ago, made it as light as possible and ran it on skinny tyres on mountain bike rims, did quite well for his
first year but all the guys that beat him said he was too light.
The next year he went to the maximum weight and changed the wheels to BMX ones and came 1st.
Volvorsport
posted on 12/2/12 at 11:38 AM |
couple of dual mass flywheels on axles .......
www.dbsmotorsport.co.uk
getting dirty under a bus
posted on 12/2/12 at 04:43 PM |
pull on!
Id agree there, they will accelerate at the same rate whatever they weigh, but the heavy one will have more momentum for the level sections.
Chippy
posted on 12/2/12 at 04:57 PM |
I had a friend that did this sport, and contrary to what has been said above he ran a micro light unit, (you could pick it up with one hand), he used
bike racing tyres that had a knife edge, pumped up really hard for the least rolling resistance. The wheel bearings were not greased, but oiled with a
thin oil at each meeting for the least friction. Now I can't say he won every time he ran, but he did have a fair shelf full of tin ware. Mind
you was a long time ago, things may have moved on since then. Cheers Ray
matty h
posted on 9/3/12 at 07:42 PM |
My item is to make a seven chassis as per the book but with everything at 60% size.Anyone know anything about what if any suspension it should
have.
Matty
MikeR
posted on 9/3/12 at 10:22 PM |
Is this a straight line down a hill or a proper race around a twisty course?
I think that may be the difference. IF you look to the scottish gravity racing (cartie?) they have lots of info. They seem to run on racing bike tyres
pumped up.
As for suspension i keep thinking that something based around compressing a tennis ball could work quite nicely.
