MydT9
| posted on 13/2/12 at 07:15 PM |
Alloy Brake Calipers + Vented discs + Alloy Coilover Dampers
Hi all,
I have a PAIR of 4 pot alloy brake calipers and vented discs from my Radical for sale, these were on my car but I have now upgraded to bigger
brakes.
These Vented Discs are Diameter 235mm x 22.5mm thick (Ford Escort Mk4 1.4 Vented) and apart from surface rust from lack of use they have had very
little use with loads of meat left - look as if new but never used.
The Calipers are genuine alloy Radical ones which are little monsters and have great stopping power, 4 pots as well !
These come complete with pads which have pad meat on them but you may want to change them as they have not been used for a while.
New as a set (1 pair) these would set you back over £600 with G+T
Looking for £225 (ono) + postage at £12.50 next day to anywhere in UK.
Also, set of 4 PROTEC alloy dampers with 21/4" inside diam springs. The dampers measure 330mm BC OPEN and 255 BC Closed (including bump stop).
The Spring rates are 350lb Rear x 6" long, and the front springs are 320lb x 6" long.
They are in good condition, threads are lovely condition and all the bump/rebound adjusters rotate with positive clicks. £325
Ideal upgrade to your kit car.
PM or Text/Call me on 07866 465125
Thank you.
[Edited on 13/2/12 by MydT9]
Myd
http://uk.youtube.com/watch?v=RPWhhbaPG4o
MydT9
| posted on 16/2/12 at 01:08 PM |
I do have 2 pairs of the Calipers and Discs and could do a deal on both together if someone wanted a complete set for the front and rear.
Myd
