Author: Subject: clutch cable
Tommy P
posted on 8/6/12 at 03:02 PM Reply With Quote
clutch cable
Type 9 5speed gearbox in a Fury.
I'm taking a guess, because I did'nt build the car - would I be right in assuming the clutch cable will be from a Sierra?
Any re-assurances welcome before I buy a new one.
Cheers Tom
OULTON PARK TRACK DAY VIDEO
http://youtu.be/-d99GbTnuuY
stevegough
posted on 8/6/12 at 05:07 PM Reply With Quote
Hi, Tom - as you know I haven't got a fury, but I have got a type 9 and I did build it myself. I used a clutch cable off a Sierra, and had to adapt the pedal end using a loop and some cable clamps (the type they use mounting Aerials on roofs). After TWICE snapping it at this point, I gave in and got on to speedy cables to do me a bespoke one - cost me nearly £50 with postage, but its never give me any problem since.
With your car, it depends on not really the type 9 bit, but what release arm has been used - this depends on your 'bellend' housing
It also depends on the pedals - if they are the standard Sierra / Fiesta type with the self- adjusting quadrant, then you may be ok with a sierra one. On the other hand, if it has a kit - car type pedal box(and I suspect the Fury is ) you may be better going down the route I used -ie. Speedycables.
HTH, Steve.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
avagolen
posted on 8/6/12 at 06:08 PM Reply With Quote
Hi Tom, can you supply pictures of the ends of your present cable?
I am building a fury and the basic cable in mine is a standard cable.
I think it is a longer one than fitted to the Sierra, but has the same ends.
Len.
Clutch Cable - Pedal end.
Clutch_Cable_Pedal end
Clutch cable pedal end 'shock absorber'
Clutch_cable_Bung
Clutch_cable_Bung
Tommy P
posted on 8/6/12 at 07:38 PM Reply With Quote
That looks the same Len - unfortunately car wont be back from the body shop till tomorrow, so cant check it out right now.
The one that's on is fine, I just want a spare for the Tour of the Alps 2012 I'm going on.
You say standard cable , then longer one - confused.com
avagolen
posted on 8/6/12 at 07:57 PM Reply With Quote
Hi Tom,
When I purchased my kit, I was recomended the longer cable as it gives extra length
to reduce the tight bend of the cable from the pedal back to the gearbox.
It is exaclty the same as the Sierra cable in build, just longer.
It goes from the cluth pedal, forward almost to the front of the engine and back to the gearbox,
allowing enough to creat a reasonable loop and not a bend.
I am not sure what the donor vehicle is, but if you give Steve at Fury Sports cars a call,
I am sure he will tell you.
Len.
Tommy P
posted on 8/6/12 at 08:50 PM Reply With Quote
thanks Len much appreciated
bi22le
posted on 10/6/12 at 12:33 PM Reply With Quote
My cable on my striker looks very similar to yours and is from a v6 capri i think.
Please read my ring story:
keithjardine
posted on 11/6/12 at 11:08 AM Reply With Quote
This is the one i used on my indy
http://www.burtonpower.com/qcc1010.html
RoadkillUK
posted on 11/6/12 at 11:23 AM Reply With Quote
I think I'm using the same one as that, can't remember, it's been in since the car was build 8 years ago, several engines later and it's still going strong
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
RichardK
posted on 11/6/12 at 01:03 PM Reply With Quote
I thought the longer version was off a transit van,dunno what model thought but mine goes nearly to the front and back and has a nice smooth arc.
Rich
Gallery updated 11/01/2011
Tommy P
posted on 13/6/12 at 05:10 PM Reply With Quote
This is it:
Ford part number: BB11062C Escort Mk2 RS 100cm Long
Kindly donated by Welderman
