Mistron
posted on 8/11/12 at 09:49 PM |
2 small stainless pins machined
Hi folks,
I'm looking for someone who could turn me up a couple of threaded pins.
I have a rough sketch available, but basically they are 10mm dia. 25mm long, with a 1mm 45 deg chamfer on the cut end. the 10mm dia then reducing to
8mm dia for 5mm, then an M8 x 35mm threaded section. There is to be a 3mm dia hole cross drilled through the 10mm dia section, 10 mm in from the
chamfered end
Could anyone with a lathe help out?
payment for time, materials and postage available, of course.
if anyone can help, please email me, or drop me a U2U
Many thanks.
Al
Alan B
posted on 8/11/12 at 11:05 PM |
Not sure if anyone else is puzzled but how can you have 35mm of thread on a 25mm long bar?...I guess that's why the sketch would be handy.
From your description it sounds like a quick release bonnet pin post?
Mistron
posted on 8/11/12 at 11:10 PM |
it's 25mm at 10mm dia, then 40mm at 8mm dia, of which 35mm is threaded. 65mm overall length
Photo: http://www.flickr.com/photos/44645707@N00/8168025713/
It's actually part of a roof rack design I'm working on, rather than part of the car itself.
Al
[Edited on 8/11/12 by Mistron]
Alan B
posted on 8/11/12 at 11:17 PM |
Ah makes sense now.....not an architect by any chance?
Hopefully someone can knock those up easily...I would do myself but the distance is a bit impractical...
trextr7monkey
posted on 8/11/12 at 11:26 PM |
Hi Al, we could easily do it if there's some 10mm studding about at work, just had a look in the garage and the only piece I can find here is
slightly curved as 'someone' must have used in to help secure an engine to an engine stand at some point!
I'll send my work e mail up and assuming no one in Edinburgh volunteers you can send the drawing once I've checked the material is
there.
atb
Mike
ps just noticed drawing in above thread
[Edited on 8/11/12 by trextr7monkey]
