Author: Subject: Tiger cat type 9 gearbox problem
navyseamonkey2011
posted on 12/11/12 at 08:27 PM Reply With Quote
Hi i am new to this group and i have just bought a tiger cat e1 and im having problems selecting first.
When I try selecting first it goes into reverse and vise versa. Ist there a linkage on the box to make it fit that could be causing the problem?????
Help would be appreciated.
contaminated
posted on 12/11/12 at 08:49 PM Reply With Quote
You've probably got a standard Tiger linkage, which is basically two strips of metal and a pivot. If you take the tansmission tunnel cover off you'll be able to see it and make adjustments. Reverse should be prevented by the lever not moving past a certain point to the right unless you press down. It's adjustable on mine.
Might be worth thinking about a Westfield remote or Rally Designs copy.
Tiger Super Six Independent
www.southernkitcars.com
