Author: Subject: Nissan Primera pulling sharply to the left ?
stevegough
posted on 11/12/12 at 07:37 AM Reply With Quote
Drove my son's car yesterday, it seems to have developed quite a severe pull to the left.
Now, in my experience, this can be down to brakes binding or low tyre pressure.
Its tyres 'look' fine, but I haven't actually checked the pressures yet, and feeling the
brake discs through the wheel, they were only slightly warm.
I have the car here in the garage today, any help / inspiration / ideas / things I can do to test it / repair it?
Thanks in anticipation of the usual helpful responses.....
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
posted on 11/12/12 at 07:44 AM Reply With Quote
If pulling only under braking then it is 95% chance a seized front calliper.
[Edited on 11/12/12 by britishtrident]
stevegough
posted on 11/12/12 at 07:58 AM Reply With Quote
No, sorry BT, its pulling is constant, and when you brake, it doesn't get any worse (or better).
Luego Locost C20XE.
mcerd1
posted on 11/12/12 at 08:37 AM Reply With Quote
suspension bushes ?
or has he hit any kerbs / big pot holes ?
stevegough
posted on 11/12/12 at 09:04 AM Reply With Quote
Originally posted by mcerd1
suspension bushes ?
Not as far as we know, I'm going to get under it shortly to inspect what I can (but its bluddee ccold out there!)
Luego Locost C20XE.
MK9R
posted on 11/12/12 at 09:13 AM Reply With Quote
just changed lower wishbone bushes and a track rod on my clio as its pulled left under acceleration and right under braking
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
mark chandler
posted on 11/12/12 at 09:34 AM Reply With Quote
Swap wheels left to right and see if the pull follows them.
Earlier this year my car suddenly started pulling to the near side, changed suspension bushes, road springs, steering rack bushes and in the end it was the tyre !
It had delaminated on its outside circumference, you only noticed when standing the two next to each other, was a very expensive Bridgestone tyre not a remould although was 10 years old.
I should have started with basics, suggest you do as well.
Regards Mark
stevegough
posted on 11/12/12 at 09:46 AM Reply With Quote
Regards Mark
Thanks, Mark - but in actual fact, earlier this morning I had already read your earlier account of this 'delaminating' and it was what I was going to do first - the tyre 'looks' ok, but you really can't tell what's happening inside it.
Luego Locost C20XE.
posted on 11/12/12 at 10:16 AM Reply With Quote
With my Nissan van it was always the brake slides sticking. It used to do it every year without fail in the winter just when you want to be messing about with cars.
mark chandler
posted on 11/12/12 at 01:23 PM Reply With Quote
Jaguar I had started doing this as well, rusty brake piston stopping the pads from releasing causing the wheel to bind.
Always happens when you least want it
ian locostzx9rc2
posted on 11/12/12 at 03:16 PM Reply With Quote
Primeras can be very sensitive to tyre issues p12 primeras with 17 inch wheels are the worst ,swop wheels over first,then check suspension bushes for wear and broken coil springs!! then look at binding brakes.. hope this is of some use.
[Edited on 11/12/12 by ian locostzx9rc2]
stevegough
posted on 11/12/12 at 03:22 PM Reply With Quote
Ok, all sorted now - it was exactly as Mark Chandler suggested - I swapped them over, and lo and behold, it pulled sharply to the RIGHT.
Replaced both front tyres, as they were both down to about 2-3 mm of tread anyway, and the car now drives perfectly!
Thanks to all you guys, once again.
Luego Locost C20XE.
