Author: Subject: 285mm Solid discs
coyoteboy
posted on 18/12/12 at 02:55 PM Reply With Quote
285mm Solid discs
Looking to spec my brakes for my middy. Does anyone know of a car with ~285mm solid front discs, with a 4x108 PCD? I'd like to stay relatively light weight on the rotors but I want to use off the shelf parts rather than custom ones. I expect the car to be around the weight of a light locost so I don't expect to need vented discs, but I'd like to run the calculations on it both ways - for that I need to find some part numbers!
contaminated
posted on 18/12/12 at 05:43 PM Reply With Quote
Hi-Spec do a 285mm conversion for the Sierra that you can have with solid discs. I think the Sapphire Cosworth used 283mm vented discs as standard.
Tiger Super Six Independent
www.southernkitcars.com
