Sloan85
posted on 19/2/13 at 09:42 PM |
Padded steering wheel centre.... Ok for IVA?
I got bored with the electrics at the weekend so made a steering wheel centre for my Mountney steering wheel. It is padded and covered in leather with
the MK logo "embossed" into it. It sticks out a bit more than i would like (i should have done the foam 5mm thinner) but what do you
think? Will this, along with the collapsable boss be sufficient for IVA?
![](http://i1051.photobucket.com/albums/s438/james_sloan85/MK%20Indy%20Build/IMG_1665_zps67059835.jpg)
austin man
posted on 19/2/13 at 10:10 PM |
I think it would be okay providing it is securely fastened to the wheel ie use of a strap to fix it to the wheel not sure if velcro would be okay
ReMan
posted on 19/2/13 at 10:11 PM |
Looks great
Dont see why it wont pass. Ver small though, does it cover enough of your dash?
www.plusnine.co.uk
Sloan85
posted on 19/2/13 at 10:18 PM |
It's got bolts built in which fix the steering wheel to the boss.
What would it need to cover on the dash?
![](http://i1051.photobucket.com/albums/s438/james_sloan85/MK%20Indy%20Build/IMG_1661_zpsebc3faaf.jpg)
deeceee09
posted on 19/2/13 at 11:53 PM |
The Momo wheel that Caterham supply with a pad adhered by Velcro passed IVA for me last year.
Treachery and old age will always triumph over youthful enthusiasm.
posted on 20/2/13 at 12:14 PM |
It's common practice to use the standard Sierra steering wheel for IVA because the area of the dashboard within the diameter +150mm of the
steering wheel, is exempt from testing.
That steering wheel looks way too small. Have you driven the car with it fitted yet? Do you have a quick rack fitted?
Phil
rb968
posted on 20/2/13 at 05:04 PM |
Just to add to the above ^^
when I had my IVA it was with no windscreen or aeroscreen and he still measured edges on a my clocks behind the Sierra wheel and I failed on a cover I
had made above my Koso RX1n.
Am at work and no time to look up the IVA manual but he did show me at the time under what section that exclusion was not valid with no screen or
possibly it was a reduced area, am struggling to recall.
Rich
Sloan85
posted on 20/2/13 at 07:48 PM |
Phil
I didn't have a sierra wheel and the ones on eBay were more than this one. Also my column came modified for quick release from MK so sierra
wheel wouldn't have fitted. Also i need as much leg space as possible. That was my reasoning behind the small wheel.
Car is a long way off being driven yet but was thinking about getting the quick rack at some point.
iank
posted on 20/2/13 at 08:13 PM |
Problem with small wheels (especially if you also have a quick rack) is they need a huge amount of muscle power to turn at slow speeds.
Check the regulations for the quick release as IVA rules are quite strict regarding not being able to operate the mechanism when moving.
The center pad looks well executed though
Anonymous
loggyboy
posted on 20/2/13 at 08:22 PM |
Rich
Ive heard this before, but cant find anything in the IVA to concur.
Mistral Motorsport
iank
posted on 20/2/13 at 09:11 PM |
Rich
Pretty sure it's Section 12 Annex 3
quote: Where the front of the passenger compartment abuts the front scuttle /
bonnet panel and no windscreen is fitted) the interior / exterior boundary shall be 25mm towards the front from the abutment.
Which I interpret as meaning everything on the dash is treated as the "exterior" from the point of view of projections if there is no
windscreen. Why that overrides Annex 1 (steering wheel exempt area) I don't know.
Anonymous
