<<  1    2  >>
Author: Subject: Rolling road nerves...
adithorp
posted on 10/4/13 at 10:08 PM Reply With Quote
The Fury is all loaded up to go for a rolling road tuning session tomorrow.
The new engine is still an 06 R1 but a bit fettled. Lightned/balanced crank and rods, ported and polished head (slight skim as well) and pretty hot cam. It came from (originally) Virgin Yamaha BSB team and is built to run to 18000rpm, so should be safe at stock 13750. Trouble is it's stood in the corner of my workshop for 2 years and was a bit tight when I put it in, so the RR could be a nervous day.
It runs/starts great and goes like poo off a shovel when you boot it but coughs a splutters on light throttle/low revs and stalls when you pull up. Hopefully we'll get it ironed out. In full race spec' it (allegedly) made over 210bhp on the engine dyno but its a bit downgraded now (not got the silly-expensive charging system that only works over 6000rpm for instance) but the biggest change is the rev range. The guy I got it from claimed 190+ from it in current trim. I'll be happy if I get that... or more if possible with the bigger exhaust and PC ignition unit.
If it all goes tits-up I'll just have to pull it out in bits and refit the old one in time for Stoneleigh.
http://jpsc.org.uk/forum/
rb968
posted on 10/4/13 at 10:29 PM Reply With Quote
I've just booked to take mine to Dale at Bailey Performance to get the V6 running on Microsquirt. I too am a bit nervous as its not turned a wheel in anger apart from a slow cruise on the drive!
Good luck!
Rich
sdh2903
posted on 10/4/13 at 10:42 PM Reply With Quote
mines booked in on the 23rd and I've never had a car on the dyno before so I have similar nerves!
Where are you having it done?
welderman
Good lucky Ady. Watching for the results, it will all be ok
Thank's, Joe
I don't stalk people
hobbsy
posted on 11/4/13 at 12:46 AM Reply With Quote
18k!!! If it is all good to 13750 then I'd say keep going. Did you see a dyno graph of it revving that far? Would sound epic and give you about 100mph in first or something daft (certainly would if still in the bike!)
Good luck in any case Adi!
hobbsy
chicade
posted on 11/4/13 at 01:04 AM Reply With Quote
Can't wait to here that signing along at blyton adi.....when you out next?
cerbera
posted on 11/4/13 at 06:11 AM Reply With Quote
Good luck Adi
TimC
posted on 11/4/13 at 07:21 AM Reply With Quote
That sounds very like an engine that I looked at once.
Good Luck.
johnny chimpo
posted on 11/4/13 at 08:25 AM Reply With Quote
Good luck today Adi, let us know how she goes!
chicade
posted on 11/4/13 at 09:43 AM Reply With Quote
And don't forget a bit of video footage adi !
franky
posted on 11/4/13 at 11:01 AM Reply With Quote
Sounds like a nice engine but none of the BSB engines were revving anyway near 18k!! Thats motogp stuff. Whats the history of the enigne.
hobbsy
posted on 11/4/13 at 11:06 AM Reply With Quote
I did think that sounded a little high. And realistically even if it did how many races would it last? Although I suppose it's a double edged sword as if you constrain the revs too much then you won't see as much of the additional power it was built to produce.
franky
posted on 11/4/13 at 11:26 AM Reply With Quote
Just to add i'm not knocking it at all but just be wary
adithorp
posted on 11/4/13 at 11:53 AM Reply With Quote
not broke yet. mapped as far as 4.5k so far.
dyno is at nine meister. some very nice stuff in the workshop.
welderman
posted on 11/4/13 at 01:03 PM Reply With Quote
keep us posted
Thank's, Joe
rdodger
posted on 11/4/13 at 04:59 PM Reply With Quote
Go on then Adi, how did it go?
CRAIGR
Contributor
Posts 2760
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 11/4/13 at 05:07 PM Reply With Quote
BANG!!!!!!!!!!!!!!!! ????????????????
Just jesting. Hope it did good Adi.
[Edited on 11/4/13 by CRAIGR]
jeffw
posted on 11/4/13 at 07:22 PM Reply With Quote
And?
adithorp
posted on 11/4/13 at 07:52 PM Reply With Quote
Well it's still running. First power run makes me wince but love to hear it going full chat after that.
A bit disappointed though... there's a huge 1.2bhp missing from what was predicted.
Made just shy of 190bhp at 188.8. Did 1/2 dozen power runs at the end and they all came out consistent, over 188. The old engine made 170. Yamaha claim 181 standard but inc' 10 from ram air (and it seems a +10 fiddle factor, as 160 seems to be a common bike dyno resut)
Torque was 125Nm. Standard is claimed at 100Nm (inc fiddle factor?) so well happy with that.
I suspect the exhaust and air box are holding it back a bit and it was set to run on normal unleaded (don't want the hassle of searching for v-power) so there may be a bit there.
Sorry, no video. I couldn't find my camera last night but it turned up today in the car... with a flat battery.
but... It's still running. Just need to book a track day and see if I can break it there.
rdodger
posted on 11/4/13 at 08:31 PM Reply With Quote
Sounds like a great result Adi!
Jim and the others will be miles behind on tour this year
CRAIGR
Contributor
Posts 2760
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 11/4/13 at 08:36 PM Reply With Quote
Good figures Adi . Nice one.
sdh2903
posted on 11/4/13 at 08:39 PM Reply With Quote
Some good figures there! very impressive torque figure.
adithorp
posted on 11/4/13 at 08:52 PM Reply With Quote
Yeah, very happy with that torque; Getting toward BUSA territory. Also explains the spinning wheels when I test drove it last week.
The torque starts to peak at 8000 and holds virtually flat from there to 10000 where the power is starting to peak and holds to 13500.
Track day booked to see how it drives on the 21st at Blyton. Just got to refit the floor and a couple of other bits.
Davegtst
posted on 11/4/13 at 09:03 PM Reply With Quote
Is that at the wheels or calculated at the crank?
<<  1    2  >>
