Author: Subject: Fitting stone guard set
carlknight1982
posted on 22/4/13 at 07:48 PM Reply With Quote
I've had a look about and ordered a set of argon fibre stone guards from kit parts direct
What's the best procedure to fit them, rivets or bonding them on?
Logic will get you from a A to B
Imagination will take you everywhere.
SPYDER
posted on 22/4/13 at 08:02 PM Reply With Quote
"Argon Fibre" you say. I bet they're light!
austin man
I would bond them personaly, they should be flexible enough you will need to tape them on while the Seal sets. PS are you sure theyre argon and not carbon lol
carlknight1982
posted on 22/4/13 at 08:13 PM Reply With Quote
Damn iphone autocorrect lol
What would you use to bond them?
J222jra
posted on 22/4/13 at 08:15 PM Reply With Quote
Bond them on using tiger seal.
Davegtst
posted on 22/4/13 at 08:26 PM Reply With Quote
Are they any good? I was looking at a set but they seemed too cheap to be decent. I would probably put them on with double sided tape. If you tiger seal them on you will never get them off again if you needed to.
carlknight1982
posted on 22/4/13 at 08:29 PM Reply With Quote
Ill let you know when they arrive tomorow
carlknight1982
posted on 23/4/13 at 06:24 PM Reply With Quote
A little thin but should do the job
rb968
posted on 23/4/13 at 06:36 PM Reply With Quote
I have them on mine. Trimmed the edges a bit.
As you said, bit thin but look ok. I riveted them on with black small rivets.
Rich
carlknight1982
posted on 23/4/13 at 07:20 PM Reply With Quote
I've never worked carbon what do I cut it with to get a nice edge
rb968
posted on 23/4/13 at 07:56 PM Reply With Quote
Tbh it's so thin I cut mine easily with a big pair of sharp scissors. No problem.
