Hopley89
posted on 29/5/13 at 04:41 PM |
Zx9r ??
Hi all Iv just spoke to cradley Kawasaki .. They have just said you have to use the original key and barrel as there is a security device in the
barrel that can blow the ecu ? Is that true or do they said that so they can charge a fortune .. If so is there a way around it ?
Iv had a bit of a problame with the coils today as I have found out that they are dead ![](/images//smilies/mad.gif)
Hope some one can help me ? Dan
40inches
posted on 29/5/13 at 04:48 PM |
You're not having a lot of luck Dan!
Have you put the 100 ohm resistor in the grey wire from ignition switch to ECU? The security device in the original barrel is a 100ohm resistor
Some good advice in this thread http://www.locostbuilders.co.uk/viewthread.php?tid=85055
Follow it until the end, then check the links in the thread.
[Edited on 29-5-13 by 40inches]
Hopley89
posted on 29/5/13 at 05:11 PM |
There is one but I don't no if any good as it was already there .. Ill have to strip the wires back and have a look ..
Tell me about it mate it dosnt help when you get the engine of someone who hasn't got a f@ckin clue lol ...
If for any reason it's bypassed dose that mean the ecu is dead ? Please say no lol haha
Dan
40inches
posted on 29/5/13 at 05:51 PM |
No, the ECU will be looking for around 9volts, if it sees 12volts it will sulk
Sent you a U2U.
dave_424
posted on 29/5/13 at 06:10 PM |
What year ZX9 have you got? I just changed over to fuel injection and megasquirt on mine and have a spare 1998 C1 CDI that you can use for testing if
you need it.
Dave
Hopley89
posted on 29/5/13 at 07:50 PM |
Hi mate Iv got a b3 but I think they all suit ? Ill send you a pic of the connection and cdi if you want to compare if that's ok mate ?
Dan
dave_424
posted on 29/5/13 at 08:12 PM |
Send away
Hopley89
posted on 29/5/13 at 08:27 PM |
What's you email ? As I don't no how to do it on hear ?
Dan
Hopley89
eBay item.. This is the same
171043364660
Dan
dave_424
posted on 29/5/13 at 08:30 PM |
Sorry but mine is this one
Kawasaki ZX9R ZX900 C1 C2 98 99 ECU cdi brains chips GOOD | eBay![](http://rover.ebay.com/roverimp/1/710-53481-19255-0/1?ff3=2&pub=5574934589&toolid=10001&campid=5336738914&customid=&item=123456&mpt=[CACHEBUSTER])
rb968
posted on 29/5/13 at 08:34 PM |
I have one of those in the garage. Had a B3/4 zx9 in my Indy.
Send me a message if its of use. Perfect working order. Got a full engine sat under a cover as well.
Rich
Hopley89
posted on 29/5/13 at 08:39 PM |
U2u rb969
Thank you anyways mate .. It good to now there is plenty people out there willing to help ![](/images//smilies/smile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/wink.gif)
Hopley89
posted on 30/5/13 at 10:27 AM |
OMG,! Iv just spoke to some one about the 100 ohm resister ?
They said I need to now what one its is ect with watts ..... Help
40inches
posted on 30/5/13 at 10:38 AM |
A 1/4watt carbon film resistor is what I used, they are about 3p each
Hopley89
posted on 30/5/13 at 10:46 AM |
Thanks rich
We're can I get it from ?
Dan
Hopley89
posted on 30/5/13 at 10:49 AM |
230899763305 are they the ones ?
Dan
Hopley89
Ebay item ..
40inches
posted on 30/5/13 at 11:08 AM |
Dan
They will do, 200 should be enough
posted on 30/5/13 at 11:24 AM |
You dont need any of it, you can bypass it easy.
40inches
posted on 30/5/13 at 11:26 AM |
How? The ECU needs to see 9volts not 12, or am I wrong?
Hopley89
posted on 30/5/13 at 11:36 AM |
Yea I think your right 40inches when I spoke Kawasaki they said the cdi needs 9vsif it has 12 it can blow the cdi unit ..
How can you bypass it ? Iv found them in maplins
Dan
Hopley89
posted on 30/5/13 at 02:20 PM |
Iv just got them from maplin .. 30p each ![](/images//smilies/tongue.gif) ![](/images//smilies/shocked.gif)
Hopley89
posted on 31/5/13 at 08:17 PM |
I GOT IT GOING WOOOOOOOOOO![](/images//smilies/tongue.gif) ![](/images//smilies/tongue.gif) ![](/images//smilies/tongue.gif)
40inches
posted on 31/5/13 at 08:21 PM |
Whose the clever boy then?
Good job Dan, like the way you stuck at it. Good feeling aint it?
Hopley89
posted on 31/5/13 at 09:08 PM |
yea the best feeling going when she fired up i was well chuffed mate ... a long process but well worth it
all thanks to you tho 40inches i would never of got it done otherwise
![](/images//smilies/tongue.gif) ![](/images//smilies/wink.gif)
