AlexXtreme
posted on 28/9/13 at 07:34 AM |
Diff mounting
Hi all, just had my xtreme mapped and on the rolling road, but more of that later. The guy doing the mapping said he felt the back axel felt loose,
and lately I have noticed a clunk when going changing from fwds to backwards at slow speed . The back end also seems to jump more over ridges in the
road, esp on m/way at over 70:-( . The car feels solid when trying to rock it from side to side.
My thoughts are could the diff be loose or if the diff is flexibly mounted and do the mounts wear out?
Other ideas could be that the suspension arms bushes are knackered but I think this is unlikely as they were replaced approx 3 years ago.
Look forward to your ideas thoughts
Cheers Alex
posted on 28/9/13 at 09:54 AM |
Check the tightness of propshaft flange bolts and the diff mounting bolts first.
Then all the bushes.
Also keep in mind a clunk when going from forward to reverse can also be caused by lost motion in the brakes.
[Edited on 28/9/13 by britishtrident]
AlexXtreme
posted on 28/9/13 at 10:11 AM |
Some good ideas and will get under the car this afternoon and tighten up everything!
I have a "top gear" style race next weekend to the watch the French round of World Superbikes in the middle of France... around 350miles
and we are not "allowed" to use toll roads and m/ways. I need to know it will stay together!
Alex
AlexXtreme
posted on 28/9/13 at 01:40 PM |
one more question probably an obvious question to some, can you lift the car on the diff with a car jack...??
jacko
posted on 28/9/13 at 02:55 PM |
I do mine is a MK indy i don't know what your car is
Jacko
AlexXtreme
posted on 29/9/13 at 07:33 AM |
It's a xtreme made by Quantum
AlexXtreme
posted on 29/9/13 at 08:01 PM |
tightened up all the bolts I could find at the back end and it is much better - slightly squeaky when manoeuvring, but much better . Some of the
diff and suspension bolts were definitly too loose on one side! Wonder how long they have been like that
Thanks for the advice British Trident!
Alex
40inches
posted on 30/9/13 at 09:26 AM |
You wouldn't believe how much noise they make when a diff mount fails, or how far the diff moves
![](/galpreviews/) ![](/gallery/)
On the plus side, no reverse motor clearance problem now
AlexXtreme
posted on 30/9/13 at 11:28 AM |
must have been pretty scary driving when it let go and was what I was worried about. How much damage did it do..... ?
Alex
