Author: Subject: Blacktop Zetec Inlet Manifolds
pekwah1
posted on 23/12/13 at 11:02 PM Reply With Quote
Hi Guys,
Just a quicky, i'm about to put a 2.0 blacktop into my Striker using stock ignition and ECU.
What inlet manifolds would bolt straight onto this engine which might be a bit smaller than the 2.0 massive plastic plenum?
madteg
posted on 23/12/13 at 11:29 PM Reply With Quote
You can get a 1.8 silver top inlet manifold of a EFI engine, this has a 30mm thick conversion plate with injectors in it. Then it is easier to make your own, just have to make the plenum. Using the original throttle body, Also if you want to fit bigger injectors in the future. Just use side fed injectors.
I am using 460cc injectors of a subaru sti that i brought for £6o of the Bay. There is some pics in my archive. Kev.
[Edited on 24/12/13 by madteg]
Scuzzle
posted on 24/12/13 at 04:22 AM Reply With Quote
The 1.6 is very restrictive with a small bore, the 1.8 115 ps is better but the 130ps HO manifold on the RS1800 Fiesta or Escort GTi is the best of metal inlets.
Like you say the plastic ones are big and bulky the metal ones are better if you have space restrictions.
madteg
posted on 24/12/13 at 07:24 AM Reply With Quote
Sorry my mistake it is the 1800.
http://www.locostbuilders.co.uk/gallery/locost%20turbo.JPG
Barkalarr
Contributor
Posts 942
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 24/12/13 at 08:09 AM Reply With Quote
I think mine is a griffin inlet plenum on my blacktop in the Indy.
Will take some pics later
big_wasa
posted on 24/12/13 at 06:54 PM Reply With Quote
You could do a lot worse than see if Daveb666 still has my old manifold, It was for sale when he changed over to throttle bodies.
JeffJeffers
posted on 24/12/13 at 07:56 PM Reply With Quote
I have a manifold that will work. I'll get a couple of pictures taken if you might be interested.
