Poll: Who uses a Wideband Lambda - Setting Up Carbs & EFI [View Results]
Don't have A Wideband
Have a wideband - but don't use it for setting up
Have a wideband - setup by others
Have a wideband - setup myself
Author: Subject: Who uses a Wideband Lambda - Setting Up Carbs & EFI
davidimurray
posted on 23/4/14 at 11:53 AM Reply With Quote
I often see questions on here about what size bike carb main jets for various applications and often the reply is get it on a rolling road. Obviously thst is the best way of setting the car up, but if you're just after a good road setup where every last BHP does not count and you are not making ignition timing changes then I don't see why more people do not setup themselves. I did my bike carb fuelling myself with a wideband and while it was a bit fiddly it was a very enjoyable process.
To me a wideband is an essential setup and diagnostic tool so i was just curious as to how many people actually use them.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
r1_pete
posted on 23/4/14 at 12:01 PM Reply With Quote
I've two, one for each bank, won't get used till I efi next winter, but will initially self setup, and then use them in a closed loop arrangement.
whitestu
posted on 23/4/14 at 12:05 PM Reply With Quote
I used one. For me the possibility of getting a day to spend at a RR was the barrier to getting it done professionally.
As it turned out the wideband wasn't really needed. I started out with a guess for the jets which turned out fine and only made minor needle height and mixture adjustments based on readings from the wideband.
I think ZX6R Mikunis must be very well suited to a 1.8 / 2.0 Zetec.
Stu
matt_gsxr
posted on 23/4/14 at 12:08 PM Reply With Quote
Wideband and EFI makes tuning with megasquirt very manageable.
If only setting ignition timing was as accessible.
me!
posted on 23/4/14 at 12:17 PM Reply With Quote
I got mine most of the way with a wideband, drove it about for a few months and drove it to Bailey Performance rather than on the back of a trailer!
Getting it set up on the rolling road didn't seem to alter the top end much so I can't have been far out. High load at low to mid RPM was much better though- I haven't spent much time comparing the maps but he spent a while fiddling about with the ignition timing in this area.
davidimurray
posted on 23/4/14 at 12:19 PM Reply With Quote
Ignition timing is the biggest pain and that is what will make good power! Could build one of these - http://www.nicoclub.com/archives/diy-knock-detection.html
[Edited on 23/4/14 by davidimurray]
Oddified
posted on 23/4/14 at 02:08 PM Reply With Quote
I did my own fuel and ignition mapping. Wide band makes the fueling quite easy with a bit of common sense, the handbrake gets some abuse mapping some areas of the map when a suitable hill/gear isn't enough though. There's plenty of ignition maps available on the internet for pretty much every engine/cam/compression combination which will get you well into the ball park, then det cans for fine tuning especially part throttle/light load cruising where extra timing makes a huge difference to general driving and fuel economy.
Ian
davidimurray
posted on 23/4/14 at 02:33 PM Reply With Quote
Ian
I've used 'general' maps to date for my megajolt and seems fine. How did you get on using det cans on the road? Were they ok?
Paul Turner
posted on 23/4/14 at 03:38 PM Reply With Quote
Bought my MBE ECU with a pre-installed map from Scholar when I injected the car. They told me the map would be close but would need tweeking on the fuel map, something they could do with a laptop and a bit of driving.
Once the engine was in and running it was better than it had ever been on carbs but a dose of looking at was needed to satisfy myself it was not lean or rich. Rang Scholar who were happy to do it but since they were 140 miles away and I am happy to tinker they suggested that I buy a Wideband and check it myself, they would talk me through any issues, even suggested I buy an Innovate LM1 from Grahame Goode.
Bought the LM1 and RPM adapter, plugged it all in and drove. Readings on the screen looked OK mostly and it recorded the data but then had to work out how to download that to the laptop. Easily done and then installed the Innovate software. Worked out how to use it and bingo, new map. After a few more runs the car ran better, far more economically and the readings were as suggested.
Downside to the LM1 is it only records 40 minutes on the built in memory. The newer LM2 has the RPM adapter built in and records as much as your SD card can cope with.
10 years on I have used it on 3 engines, saved me a fortune in visits to Rolling Roads.
Well worth the investment.
Oddified
posted on 23/4/14 at 03:42 PM Reply With Quote
Ian
They work fine, you soon learn what noise to listen for ignoring the general engine noise. They just make it easier to hear the 'tinkling' rather than just by ears alone.
Scuzzle
posted on 23/4/14 at 04:42 PM Reply With Quote
I have one fitted but I got my bike carbs and MJ set up by Bogg Bros, I will continue to monitor mine but it's really only to make sure I am not running dangerously lean and it should show if my carbs ever go badly out of tune.
coyoteboy
posted on 23/4/14 at 05:58 PM Reply With Quote
Top tip for ignition - if you have a decent car stereo in your car (less likely in a KC) you use the aux in to bring the signal from the knock sensor and use the graphic equaliser to knock out high and low frequencies leaving only those around 4-6KHz, which is ideal for listening to knock
Jenko
posted on 23/4/14 at 09:02 PM Reply With Quote
On my previous Westfield, I used megasquirt with a techedge wide band. I spent a fair amount of enjoyable time mapping it and was conviced I had almost perfected it........Northampton motorsport proved me wrong by extracting another 8 bhp out of it, a load of torque, and vastly increased fuel economy. As mentioned, shame you cant get the ignition spot on. That said, taught me lots about mapping.
MY BLOG - http://westfieldv8.blogspot.co.uk/
