Author: Subject: Oil catch tank from ebay
TrophyJem
posted on 9/5/14 at 11:33 AM Reply With Quote
Has anyone used one of these?
OIL CATCH TANK VW GOLF GTI GTD VR6 9MM &' 15MM FITTINGS INCLUDED RED SQUARE
Are they up to the job, or just not worth the money?
Its for use on a road going duratec engine.
Jenko
posted on 9/5/14 at 11:59 AM Reply With Quote
At the end of the day, it's just a catch tank....some people sucessfully use a coke can or plastic water bottle to do the same job. I agree there some dodgy cheap ebay chinese items out thier but as a catch tank I think this would be absolutly fine.
MY BLOG - http://westfieldv8.blogspot.co.uk/
leon51274
posted on 9/5/14 at 12:29 PM Reply With Quote
I had a similar one, the tank itself was fine, just the fittings ie jubilee clips are a bit pants.
TrophyJem
posted on 9/5/14 at 12:36 PM Reply With Quote
I thought the clips and the pipe might not be up to much, but I'm not worried about replacing those with something half decent.
adithorp
posted on 9/5/14 at 01:59 PM Reply With Quote
I've seen them at shows. Look OK, if a bit over engineered (even bling) for a catch tank.
http://jpsc.org.uk/forum/
hobbsy
posted on 9/5/14 at 02:36 PM Reply With Quote
I bought a similar one to that and it was pretty heavy compared to more expensive versions.
Depends how weight obsessed you are.
Won't get much lighter than a redbull can or similar Guess it depends how much your engine breathes?
snapper
posted on 9/5/14 at 03:48 PM Reply With Quote
If you run crankcase and rocker cover to it, it won't breath
I eat to survive
I drink to forget
TrophyJem
posted on 9/5/14 at 04:09 PM Reply With Quote
I could either T them together and use one fitting leaving the other for a breather, or drill the top for a breather.
Eltel
posted on 9/5/14 at 05:41 PM Reply With Quote
I've also been looking at these and for the money it looks like a good buy
Bluemoon
posted on 10/5/14 at 08:20 AM Reply With Quote
Not as cheap as a aluminium bike water bottle
Just remember it's function is quite simple really. Not sure I could see a breather filter, might be worth fitting on if you feel like it...
Dan
posted on 10/5/14 at 08:23 AM Reply With Quote
Looks very much like the one CBS sell ,have had one on my car for a few years now with no problems although as said the hose and clips aren't brilliant
