Author: Subject: front wings
skinny
posted on 24/11/04 at 11:42 AM Reply With Quote
front wings
how much room are peeps leaving between their front wheels and wings (or mounts) - do the sides of the wing actually go around the tyre or do they sit a little apart?
if you don't fail, you aren't trying hard enough.
posted on 24/11/04 at 12:03 PM Reply With Quote
You need a bit of space, otherwise you can't get the wheel off...
skinny
posted on 24/11/04 at 03:13 PM Reply With Quote
yeah, i saw that problem coming when the ends of my wing stays bend around the tyre and i could only take it off as the tyre was flat!
enough gap to put your fingers onto the tread of the tyre sounds sensible?
