mk85
posted on 11/3/15 at 10:52 AM |
tiger seal and my fuel tank
Would I be fine if I used tiger seal to fix my fuel tank in place
adithorp
posted on 11/3/15 at 11:09 AM |
I wouldn't. You'll not be able to remove easily it should you ever need to. Also Tiger seal is affected by perol (it softens and swells)
should you spill any or get a leak.
http://jpsc.org.uk/forum/
posted on 11/3/15 at 11:15 AM |
No, needs fixing with brackets and foam. Then in a shunt it can move around without ripping open. Fixing down with tiger seal would mean the top
moving, bottom stock tear rip spill..
Ben_Copeland
posted on 11/3/15 at 12:38 PM |
As above... no, needs fixed straps around it
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
kitcardirect
posted on 11/3/15 at 12:47 PM |
yep just make some straps from thin ali bent over the tank and secure with bolts or rivnut bolt safest way
theprisioner
posted on 11/3/15 at 12:52 PM |
Petrol dissolves Tiger seal/Silcoflex etc
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
adithorp
posted on 11/3/15 at 01:23 PM |
Tank straps should be steel rather than ally.
I had a full tank fall out of a Striker right in front of me on track once Fuel spraying everywhere but luckily an ally tank so no sparks as it
bounced around. The ally straps had broken where they were bent around the tank (suspended on Strikers/Furys). After that I inspected my ally straps
and found cracks in the same places so replaced with steel. I just cut 2x 1" strips off a sheet of 20gauge.
You should have a rubber between the tank and strap. I just threaded the strap through an old bike inner tube.
Jon Ison
posted on 11/3/15 at 01:49 PM |
Off to check my ally straps, thanks for the heads up
garyo
posted on 11/3/15 at 02:18 PM |
My old Westfield straps were ally. The tank was sat on the spaceframe though so not taking nearly as much load as a dangleberry tank.
40inches
posted on 11/3/15 at 02:37 PM |
I used ally straps, done 3000miles still OK. But I did make sure that the straps didn't take any bending stress, I braced them against the rear
bulkhead and side chassis members.
![](/galpreviews/DSCI0599 [640x480].JPG) ![sender](/gallery/DSCI0599 [640x480].JPG) sender
![](/galpreviews/DSCI0600 [800x600].jpg) ![mounting straps](/gallery/DSCI0600 [800x600].jpg) mounting straps
adithorp
posted on 11/3/15 at 04:56 PM |
The cracks in mine (and the one that fell out) were in the tight 90deg angle where you've folded the end over bolt it up.
40inches
posted on 11/3/15 at 05:56 PM |
The ends are pieces of angle riveted on to the strip ![](/images//smilies/wink.gif)
adithorp
posted on 11/3/15 at 07:36 PM |
The tank in question...
Was scary at 90mph.
