Author: Subject: RING Boost Pack Charger info
ash_hammond
posted on 12/1/16 at 03:36 PM Reply With Quote
Hi Gents.
I have one of the following boost packs from Ring.
The charger has been lost. Does anyone have one so they can tell me the output of the charger plus the diameter of the barrel back so i can order one from ebay.
Ash
.: www.mac1motorsports.co.uk | www.m1moc.com :.
PSpirine
posted on 12/1/16 at 05:14 PM Reply With Quote
I've used a 12v drill charger for mine (same RING model)...
To be honest any brick with a ~6mm (can't remember exact size but I had loads that fit) connector that outputs 13.5-15v ish should do (that's what it would see when plugged into the car via fag adapter).
ash_hammond
posted on 12/1/16 at 05:20 PM Reply With Quote
If you could measure it that would be appreciated...
Don't have any spare kicking around that fit. It's been sitting around for ages so i don't want to waste the money on an original one if the unit is caput!
Ash
hizzi
posted on 12/1/16 at 07:40 PM Reply With Quote
I back charge my pack with a standard car charger through the croc clips
ash_hammond
posted on 12/1/16 at 09:25 PM Reply With Quote
crock clips to crock clips with a normal battery charger??
hizzi
posted on 12/1/16 at 09:32 PM Reply With Quote
yes works a treat, just make sure your pack is switched on, mine has a switch that isolates the croc clips when not in use, its probably not the politically correct method but has worked for me for the last few years, also charges the pack better
ash_hammond
posted on 12/1/16 at 09:38 PM Reply With Quote
Cool thanks for the idea.
It has not been used for over 10 years, there is power there as the compressors runs, but i dont want to invest any serious money if the battery is DOA.
Cheers.
steve m
posted on 12/1/16 at 10:30 PM Reply With Quote
I had a 20k garage fire ," because I may of plugged the wrong item into something "
so would it be sensible to plug anything into the charger , without knowing it was compatible ??
I know now, I wouldnt
ash_hammond
posted on 13/1/16 at 01:47 PM Reply With Quote
^^ Agreed. First few time i wont certainly not leave it unattended.
