Author: Subject: Rear Caliper removal
AlexXtreme
posted on 21/2/16 at 04:59 PM Reply With Quote
I am trying to replace my rear caliper and getting a bit frustrated ... last plan was to take it to a motor factors to find out which one it is however I can't get it off! Does the cable come with the caliper or is it removable?? I can't see how I can get the cable off the caliper. Hope this picture gives enough info?
https://picasaweb.google.com/lh/photo/SYdFkifYzCKV4KHQClotRG-vWs37cn_gW1jg_vRcqYg?feat=directlink
Any suggestion?
Alex
[Edited on 21/2/16 by AlexXtreme]
Slimy38
posted on 21/2/16 at 05:13 PM Reply With Quote
The end of the cable hooks over the end of the part that operates the handbrake. If you rotate the part clockwise (IE the same action the cable would do in normal operation) you should then be able to unhook the cable from the end.
Be aware, the last time I did something like that, it was incredibly hard work. I'd probably look at trying to get a screwdriver through the egg shaped hole in the rotating part and the hole in the caliper itself. Then you should have an easier time removing the cable.
AlexXtreme
posted on 21/2/16 at 05:30 PM Reply With Quote
I thought I had tried that but oblivious not I did not try hard enough! The part did not seem to rotate that far and not far enough to be able to unhook the cable...
How does the cable sheave detach from the caliper (assuming I can up hook it!) or is it obvious..
Alex
Ugg10
posted on 21/2/16 at 05:32 PM Reply With Quote
Obvious point - have you slackened off the handbrake adjuster fully and put the and brake in the off position ? Sheath is just a push in fit IIRC.
[Edited on 21/2/16 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
AlexXtreme
posted on 21/2/16 at 05:50 PM Reply With Quote
hand brake off but not slacked off hand brake cable.... good idea!
cheers Alex
big-vee-twin
posted on 21/2/16 at 06:54 PM Reply With Quote
You need a lot of Slack to get it off.
http://www.triangleltd.com
CosKev3
posted on 21/2/16 at 06:56 PM Reply With Quote
Yeah as above,you'll struggle without slackening the cable!
Then the fitting will slide off,front part of the 'hook' first.
posted on 21/2/16 at 08:05 PM Reply With Quote
If you are having problems with the caliper it could be as simple the cable is just over tensioned. If the cable has tension in it in the off position the self-adjusting mechanism can't work. This type of caliper needs a fair bit of free play in the cable with the handbrake lever in the off position for the self-adjuster to work.
AlexXtreme
posted on 21/2/16 at 10:38 PM Reply With Quote
I has 1 mm or 2 mm of slack however it was binding always on one side...
