agors
posted on 31/7/16 at 06:38 PM |
Wheel stud Westfield help!
Hi all,
I'm pretty sure that you knows what's the wheel stud dimensions of a Westfield with cortina drum on the rear and escort disc on the
front.
Can you help me?
I want to be sure before buying wrong wheel!!
4x108?
gremlin1234
posted on 31/7/16 at 07:51 PM |
pcd is not the only thing you need to know.
you also need to know the wheel width, (and the tyre you are putting on) and their 'offset' and obviously the wheel's diameter.
there are other parameters too, including centre bore, stud size, ( and length)...
what does it currently have?
agors
posted on 1/8/16 at 06:18 AM |
Hi gremlin,
The pcb is what worries me, since the other info are usually written on the wheel.
Is 4x108 correct?
ian locostzx9rc2
posted on 1/8/16 at 08:07 AM |
Yes 4/108 is correct for ford wheels
