dai1983
posted on 19/4/17 at 01:25 PM |
Spacing Brake Pads (vented->solid)
Hello,
Im looking at making a midi from something FWD late 90s/early 00s Ford and the front brakes go from 140mm-300mm. A lot of the smaller cars have drums
at the rear but solid Focus rear disks start at 258mm.
I read on here that someone spaced vented calipers out by welding old pads minus friction material onto new pads to create a solid set up. Is that a
done thing and is there any other way to go about it?
I've also thought about fitting solid rear calipers on the front with the hard brake mech disabled. I think this could potentially be the worse
route to take due to the difference in rear calipers to the front.
Failing that I could just fit 280mm vented at the front from the likely donor and live with the resulting weight and cooling penalty. Would be the
cheapest and less hassle though.
theconrodkid
posted on 19/4/17 at 02:35 PM |
erm,sounds a bit dodgy to me.
why try to re-invent the wheel,just check what others have done,it,s a fairly well troden path and you will need the bigger brakes up front due to
weight transfer when braking.
who cares who wins
pass the pork pies
Nickp
posted on 19/4/17 at 03:11 PM |
Just NO!!
There will be a caliper out there to suit a solid disc without having to resort to such bodgery ![](/images//smilies/wink.gif)
Ugg10
posted on 19/4/17 at 04:18 PM |
Sierra Cosworth 2wd / XR4x4 rear brake calipers, solid disc Mk1 Mk2 Escort BR-43
2nd hand ones
Ford sierra cosworth rear calipers
There are solid rear discs on sierras, 253mm. So long as you either have a bias pedal box or a valve in the rear circuit you can get the front to rear
ratio right.
There are also 240mm solids on the front of the mk3 fiesta, escort and Orion if that helps.
Ford Escort MK7, Ford Fiesta MK3 - Eicher Premium Front 239.5mm Solid Brake Disc
You may be able to use these with the Sierra calipers with a suitable bracket on the fiesta/escort/Orion uprights. That will give you the small discs
with a handbrake caliper. This is a fairly standard mod on an English axle.
This may also be interesting - R1ot with fiesta hubs and BMW mini calipers.
https://jpsc.org.uk/forum/viewtopic.php?t=679
[Edited on 19/4/17 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
dai1983
posted on 19/4/17 at 04:48 PM |
Just NO!!
I was surprised when I read it on here TBH as its a total bodge!
mcerd1
posted on 20/4/17 at 07:19 AM |
I'd avoid the bog standard mk1 focus hubs them - they have integral caliper mounts / pad guides, so won't offer many options for swapping
them...
mk1 focus hub: (I think early 4x108 mk3 modeo's use the same hubs)
on the other hand the 90mm bolts centres for teh caliper mounts used on the sierra is pretty standard across loads of models and even some other makes
[Edited on 20/4/2017 by mcerd1]
dai1983
posted on 20/4/17 at 09:08 AM |
them...
Was thinking Mk1-2 Mondeo/Cougar v6 more than anything else. They have 280mm vented on the front with seperate caliper brackets and but vented on the
rear. Thinking about it the most "Locost" spirited version would be to use the front calipers and put something more lightweight on the
rear such as Focus solid, VW alloy etc:
mcerd1
posted on 20/4/17 at 09:56 AM |
Sounds like you need to get your hands on an aftermarket disc catalog to search for your ideal sizes
