striker-4age
| posted on 27/8/17 at 11:24 AM |
Led headlight bulbs ??
Hi there
What are the best bulbs to use in a 7 style headlight ??!
Mine seem pretty crap, so just wonder what others have fitted ??
| posted on 27/8/17 at 03:14 PM |
Unless you plan on replacing the entire sealed unit don't bother, they'll just blind other drivers and fail at MOT.
ianhurley20
| posted on 27/8/17 at 05:03 PM |
I don't have any problems - then again I don't drive at night. :-) That said I think it is something to do with being lower than the
headlamps - most cars find you above them by some way but with a seven you look underneath the headlamps and don't get the same amount of
reflected light. That's why I don't drive at night in a seven!
striker-4age
| posted on 27/8/17 at 05:32 PM |
What is the normal wattage for the headlight bulbs ?
Maybe I can just put more powerful standard type bulbs in ?
Myke 2463
| posted on 27/8/17 at 05:57 PM |
Try these GE 477 H7 +130 Brighter Headlight Bulb from Halfrauds Use these in all our cars still legal.
Be Lucky Mike.
cliftyhanger
| posted on 27/8/17 at 06:41 PM |
I use philips extreme. Very good. But also what headlight units? many of the cheap ones are just not very good. When I changed to theclear lens
"crystal" type it was another huge improvement.
And check the voltage at the bulbs, poor connections etc can mean big losses in light output (compare voltage across battery terminals and from neg
terminal to the light bulb connection. Should be near enough the same, certainly much less than 1/2V difference)
| posted on 28/8/17 at 09:08 AM |
quote: Originally posted by striker-4age
Hi there
What headlamps are you using? The little "Dominator" bike headlamps are well known to be particularly crap.
