chrisbmxr
posted on 2/7/18 at 12:02 PM |
Electric Reverse
I currently have an MK Indy (Fireblade 919cc) which has an Elite racing reverse gearbox fitted, which I hate!!! So I'm looking to switch it to
an electric reverse system. I'm looking for any advice from anyone who has already done this!
Are the kits MK provide any good? http://www.mksportscars.com/electric-reverse-kit-1118.html Are there alternatives?
I think I'll need to get the mounts welded on to my chassis ... anyone know where I can get these from (the threaded mount bits)?
Also, I'll be needing a new prop so any recommendations on suppliers would be great!
Thanks!!!
CosKev3
posted on 2/7/18 at 02:22 PM |
Personally I wouldn't bother if I was in your situation.
The electric reverse will only move the car on the flat,or very slight inclines,and that's if you have a full size car battery fitted?
If you have a bike battery or a lightweight race one it will be worse than useless!
As you say you've got to weld in mounts, which could include removing brake and fuel pipes down the tunnel to start with.
Then you've got the issue of getting the mounts welded in exactly in the right place for alignment to the gear on the diff.
Easily done on using a jig when the chassis is being built!
CosKev3
posted on 2/7/18 at 02:25 PM |
Oh yeah and Bailey Morris for your propshaft ![](/images//smilies/smile.gif)
chrisbmxr
posted on 3/7/18 at 07:35 AM |
You mean you just wouldn't bother having a reverse? It has crossed my mind.
Thanks for the prop recommendation. I take it I will need a full new prop? Is it not possible to use some sort of small prop 'extension'
to replace the reverse box?
Thanks again.
CosKev3
posted on 3/7/18 at 07:41 AM |
Yeah I meant don't bother with a reverse at all if you don't like the reverse gearbox currently fitted!
Perhaps it just needs a service?
What's the issues with it?
Yeah you will need a new propshaft in full,a two piece one with a centre mount.
Actually you will need to check that you have the mountings on your chassis to mount a propshaft without the reverse gearbox being in place, as
it's a kit car it could have been modified to allow the reverse box to be mounted.
Bunje
posted on 3/7/18 at 07:57 AM |
theres a bike propshaft on ebay
https://www.ebay.co.uk/itm/Locost-Kit-Car-Megabusa-Westfield-Motorbike-Full-Prop-shaft/173382405484?hash=item285e658d6c:g:vl8AAOSwQKlbIMNU
nothing to do with me though just noticed it when i was browsing
[Edited on 3/7/18 by Bunje]
INDY BIRD
posted on 3/7/18 at 12:56 PM |
New ones available here
http://www.mksportscars.com/propshaft-for-bike-engine-cars.html?SID=nho4o33ufksiio76prvhn0j7k1
