myke pocock
posted on 16/3/23 at 01:58 PM |
Video to PC
I have a number of video tapes of motorsport and other things that I would like to download to my PC. Is there any programme that is free I can
download so that I can connect my video camera to the PC and copy the footage over?
Mr Whippy
posted on 16/3/23 at 02:18 PM |
You can get a cheap USB adaptor that just plugs in and free software off the web but beware, most are not free to get full functionality plus a lot of
websites that appear to be reviews of the best 5 apps are in fact scams that actually just lead to one. Wondershare being one of those I'd
avoid.
I tend to try and get all my software from the Microsoft store, but can't check for an app on this computer.
obfripper
What type of camcorder is it?
Sony and panasonic ones can usually be connected by firewire (also known as dv-link, iee-1394), this requires an existing firewire port, or an
internal pci adaptor card(it's possible your pc motherboard has a header with no connector, so may be worth checking.
On other makes this connector is less common, and without it the only way to transfer video is using an analog video capture card, this can be an
internal desktop card, or an external usb device (requires at least a usb 2.0 connection).
The capture card will usually come with bundled software that should be capable enough, firewire devices need software, something free like windv will
suffice to just control/capture from the camcorder.
Dave
gremlin1234
posted on 16/3/23 at 02:28 PM |
is it just a standard vhs tape?
else depends on the camera, does it have a digital output of any form?
you will need a digitising card of some description,
or a video to dvd device.
as for software after its on the computer, I have recently been trying 'DaVinci Resolve' free, quite a steep learning curve for it, but it
seems to do most things, and free
[Edited on 16/3/23 by gremlin1234]
nelmo
posted on 21/3/23 at 04:07 PM |
I recently did this and you would not believe the hassle it is!!!
I couldn't find any of those 'free' packages that would work - the biggest problem was connecting the camcorder up. I have an old Sony
TRV10 which has a Firewire output, DV output and some others - all useless because no vaguely modern PC has those connections. I even tried a PCI card
in a desktop - didn't work, no idea why.
I eventually got it to work BUT it was a nightmare. I'm not going to be a huge amount of help here as I have sold the Mac I used and I can't
remember exactly what was needed but I'll do my best to point you in the right direction...
First off, you need an Apple Mac - won't work with Windows. It also has to be a Mac with a certain version of the OS on it - not the latest but
not too old either. You need a Mac with a Thunderbolt (?) port, which looks like a USB-C port but isn't; it's an earlier version of the
USB-C port.
You then need about £75 worth of adaptors (Apple, hey!) - one to go from the Firewire of the camcorder to a different version of Firewire (smaller or
something?), then an adaptor to go from that to a mini-USB (?) and then a final one to convert the mini-USB to the Thunderbolt. Something like that...
(I've got pics of the adaptors if you want them?)
You also need iMovies on the Mac (not available any more, which is why you need an old-ish Mac) and then it can record from the camcorder to an MP4
file.
If anyone finds a better way, please God let me know...
[Edited on 21/3/23 by nelmo]
Build Blog
HowardB
posted on 22/3/23 at 09:51 AM |
I know someone that has one of those video players the played VHS and recorded to DVD,. A quick google showed up a few models that are still around.
Howard
loggyboy
posted on 22/3/23 at 02:20 PM |
Software isnt the issue, windows movie maker can record videos from a source camera, you just need a suitable AV to USB adapter - £20 -£30.
https://www.youtube.com/watch?v=TcfzRJ60jwU
Mistral Motorsport
posted on 22/3/23 at 03:06 PM |
Handbrake is a very good free video transcoder, once you actually get the video moved onto your computer.
LINKY
Works on most operating systems. Quite "technical" but most defaults work well.
