Author: Subject: Tyres for track days
jester
Contributor
Posts 175
Registered 21/5/17
Member Is Offline
Photo Archive Go!
Building: brought Jester.building a Jester own a Striker
posted on 28/4/24 at 11:25 PM Reply With Quote
As the subject above
I have had the Striker a few years now & I am hoping to finely do some track days
After sorting a lot of problems out with it.
The Striker currently sits on alloys with Yokohama A539 tyres
The question is are these ok for track days ( to get the best out of the Striker)
Or do I need to spend out on some super sticky tyres like Proxes
I might well be driving to and from the circuit in the Striker
Thanks in advance
posted on 29/4/24 at 05:37 AM Reply With Quote
You'll have fun either way. If you've got 500 quid spare, new tyres are always satisfying. Are the current tyres anywhere near properly worn out? That would be my deciding factor, but I'm kinda tight. You're only talking about a second a lap. Plus it might rain on you anyway and you'd want different tyres.
JimSpencer
posted on 29/4/24 at 07:35 AM Reply With Quote
Hi
Probably the bigger question is how old are the current Yoko's?
If they're knocking on a bit.. then simply new tyres will be a huge improvement, could be another set of them, or you could go for performance and something like Toyo 888r's. If you go for the performance type then, depending upon the milage you do (or don't do!) I'd also suggest a soft compound as given the lack of mileage a lot of our cars see, tyres often age before they wear out, so one might as well have a bit more grip..
Some people will say that a pure performance tyre like the 888's is a problem in the wet.. personally I've found that nothing works that well when it's properly wet.. and up to that point a performance orientated tyre in a soft compound works better..
If you're out and it does get suddenly very wet, find somewhere to stay dry until it's not, has been my approach
bi22le
posted on 29/4/24 at 01:54 PM Reply With Quote
To answer your question directly, yes A539 are fine for track use but you can get better.
As mentioned some road legal semi-cuts like R888R will give you more corner speed and general grip confidence. They will get you to the track and back as well, just make sure they are road legal at the end of the day!!
If you are driving to the track, and you like pushing hard on track then I think a semi-cuts is best. Otherwise the all rounder / road focussed tyres will get hot too quick and go hard, this won't give you what you need on track or the road.
Please read my ring story:
yogibear1969
posted on 30/4/24 at 11:45 AM Reply With Quote
Thanks in advance
I'd sat the A539's were a great tyre when new, but I susepct they are quite old and hard. I know mine, which were second hand went quite hard and offered little grip. I'd see how they go!
Edd
posted on 30/4/24 at 12:43 PM Reply With Quote
I just put some ns-2rs on mine - the old tyres that came off were 22 years old
