limpetminer
posted on 21/11/24 at 08:19 PM |
R1 sump baffle
What is required sump wise on early R1 engine, is it a baffle plate or full baffled sump? thanks in advance for advice
adithorp
posted on 21/11/24 at 11:01 PM |
Baffle plate and slight overfill. Some version s need a few other tweeks. Which model/year?
http://jpsc.org.uk/forum/
limpetminer
posted on 21/11/24 at 11:17 PM |
Engine is year2000 on carbs
adithorp
posted on 22/11/24 at 06:05 PM |
Its a bit earlier than my knowledge but just a sump baffle then as far as I know.
hobbsy
posted on 23/11/24 at 08:27 PM |
Yeah baffle plate and a 250ml overfill if I recall. Half way up sight glass when running and warm rather than an empty sight glass I think.
[Edited on 23/11/24 by hobbsy]
limpetminer
posted on 30/11/24 at 07:09 AM |
I have just bought a MNR Vortx with a R1 2201 motor, I would like to try the car but am worried that it might not have a sump baffle fitted .Is it ok
to just overfill sump as advised & give it a quick drive before I take sump off & investigate?
adithorp
posted on 30/11/24 at 08:49 PM |
You should be ok. It only becomes an issue cornering hard.
