Author: Subject: Bike clocks
muzz
posted on 10/2/05 at 10:28 PM Reply With Quote
Bike clocks
How difficult is it to get the speedo recalibrated if you use the bike clocks. Im building an Indy with a GSXR1000 from a 2001 bike. The speedo pick up is electric. Its just I cant foil over £500 for dials.
subk2002
posted on 10/2/05 at 10:32 PM Reply With Quote
Just buy a speedohealer think thay are about £60
http://www.speedohealer.com
[Edited on 10/2/05 by subk2002]
alister667
posted on 10/2/05 at 11:19 PM Reply With Quote
Yep I used a 'yellowbox' to re-cal the bike clocks (much the sam as the speedohealer), or you can have a set of new backgrounds printed for the speedo, but remember the odometer will be still out if you do this.
The speedohealer method will mean your odometer is spot on.
http://members.lycos.co.uk/alister667/
posted on 11/2/05 at 04:21 AM Reply With Quote
Use this - the range of correction is larger than the Yellowbox in case you need it... and it's cheaper!!!
[Edited on 11-2-05 by Hellfire]
muzz
posted on 11/2/05 at 06:27 AM Reply With Quote
Thanks for the help boys !
