whpracer
posted on 10/3/05 at 06:09 PM |
classic lotus design needed
A friend of mine is thinking of building a classic kind of formula car , just like the Tiger E.R.A. are there any drawings and measurements of this
kind of car on the internet ?
this is the kind of racecar he's going to build.
![](/galpreviews/a189969-english-racing-automobiles-era-drawing.jpg) ![Rescued attachment english-racing-automobiles-era-drawing.jpg](/gallery/a189969-english-racing-automobiles-era-drawing.jpg) Rescued attachment english-racing-automobiles-era-drawing.jpg
kb58
posted on 10/3/05 at 06:34 PM |
The problem with getting plans for something like this is, unless you use *exactly* the uprights they used, the wheel geometry will be wrong. Sure
you can redesign it, but now the in-board pick-up points probably move, which means moving tubes. Once that starts all sorts of seemingly unrelated
things come into the picture.
Yes, for reference, the original drawings would be helpful, just don't assume they can be copied as-is unless all components are exactly the
same as the original.
And its book -
http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
ceebmoj
posted on 10/3/05 at 07:38 PM |
hi,
also you might what to see if you can find some one who sels old single seater as you can pick one up - gear box and engin for not a lot then all you
need to do. is fabricate a frame to take the plave of the gear box if you are going bike powered.
blake
posted on 10/3/05 at 08:15 PM |
There are a some early Lotus racer original drawings kicking around on the web --- you find pictures of some early 60s Lotus F1 parts at ths url
http://www.leechapmanracing.com/
More generally many F1 F2, FJ and even some Indy cars of the early 60s used Herald uprights. The 18 in particular had a chassis and front suspension
that had a lot in common with the Eleven and Seven S1 and S2 and SŁ. Lotus stoped using Herald parts in F1 & F2 from the 24 onwards when they
switched to rocker arm suspension with special cast uprights but the front geometry was essentially the same as the Herald based suspension. Brabham
used the Herald front end parts (with great sucess) for much longer.
Lotus again used Herald parts on the original Formula Ford car the 51 (and the later rebodied 61) which was really just a reworking and dumbing down
of the the early 60s F2/FJ cars .
Rear suspension wise all that is needed is to copy any Formula Ford built up to around 1980.
