pdw709
posted on 1/9/05 at 08:47 AM |
Fuel Economy...
What sort of MPG are you guys getting from your BEC's? I hav'nt done the calculation myself because I don't have a working fuel
gauge, but judging from the rate that the fuel is dissapearing from the tank via a visual inspection then i'm not getting much more than
20-25mpg. Is this normal?
Brooky
posted on 1/9/05 at 08:56 AM |
yeah pretty much, i stopped working it out cos it upsets me too much . Just have fun in it !
shortie
posted on 1/9/05 at 09:02 AM |
I noticed that mine seems to enjoy a good drink!! Right foot down = more juice so it's a bad combination in a BEC!
posted on 1/9/05 at 11:02 AM |
Sounds about right to me too... make the most of it, trackdays you'll return much less.
posted on 1/9/05 at 11:46 AM |
BTW - Which bike engine?
pdw709
posted on 1/9/05 at 12:47 PM |
CBR1000 Engined Striker.
Not the most powerful engine, but with a kerb weight of 398Kg the 130bhp is fast enough for me. I'll probably be sticking with it for the
short term until it blows up or needs replacing. In which case I may think of somthing a bit more potent (fireblade/R1/hyabusa or something !)
One thing is for certain i'll be sticking to a bike engine - I dont think a car engine could match the experience!
Phil
jimgiblett
posted on 1/9/05 at 02:22 PM |
I got 20mpg on track and 30+ on the road out of my carbed R1. Funnilly on trips I have found that I am more economical than my my mates in their
furyblades. May be because of not being quite so hard on the pedal at similar speeds?
wilkingj
posted on 1/9/05 at 04:26 PM |
Wow!! those BEC's are quite good on the fuel.
My petrol Landy did 15 Mpg solo, and 9Mpg with a caravan on the back, and 0-60 in about half hour. ie Flat out at 60.
That one was 35 years old (and fully rebuilt)
My Diesel everyday Landy does 26mpg solo, and 22mpg with the Caravan. Tows at 70mph+ all day, which I dont think is too bad for a rig weighing in at
nearly 4 tons.
This one is a youngster at 21 years old, and I have had it for 11 years and done 100k miles in it. Its now totalling 189K miles and still going
strong.
Best Regards
Geoff
http://www.v8viento.co.uk
ChrisGamlin
posted on 1/9/05 at 04:53 PM |
Blades seem quite economical overall, certainly my blade engine was more economical than the injected R1 is, although thats to be expected as it is
30bhp+ extra and isnt properly mapped yet (using a map from another R1 BEC).
On the road I used to get around 30-35mpg with the blade, and even 25mpg or so on track. The R1 from early experiences is around 5-10mpg below both
those figures. Still, its better than a Busa, a friend's Megabusa used to go through almost twice as much fuel on a trackday as my blade did
posted on 1/9/05 at 05:30 PM |
Did you mean 60, it's been pointed outsomewhere that you can be prosecuted for incriminating yourself and that is over the legal limit for
towing . Probably meant on a private road.
bimbleuk
posted on 1/9/05 at 06:54 PM |
Striker with 20V 4AGE fitted (injected).
low 30s on the road. No fuel gauge the last time I was on track but I guess I'd rather not know anyway!
I'm going to fit the lambda sensor and run closed loop on light throttle to see if it improves the mpg.
