Author: Subject: zetec clutch
Dusty
posted on 12/7/06 at 09:35 PM Reply With Quote
zetec clutch
Using mondeo 1.8 flywheel, pressure plate and spinner on blacktop 2litre with type 9 box. Two new pressure plates and spinners in three weeks due to slip. No oil leaks. Has cable freeplay. Getting the flywheel refaced but it seems flat and unridged. Any recommendations for mildly uprated items.
APR
posted on 12/7/06 at 09:38 PM Reply With Quote
hi
im using 2.0l flywheel with std clutch and cvh release bearing with no problems on blk top /type9.
adrian
stevebubs
posted on 12/7/06 at 09:39 PM Reply With Quote
Hm...
I'm using a Dunnell-supplied item - lightened 1.8flywheel + clutch
2000 miles so far without problem...
Dusty
posted on 12/7/06 at 11:14 PM Reply With Quote
I still have the 2L flywheel in the garden but it weighs a ton and I know most people use the lighter 1.8 item with no problems. Can't work out what I'm doing wrong! Possibly pattern parts not up to standard?
As I'm about to start phase 2, 285 cams and head mods I want this weekends engine out for new clutch to be the last for a while!
[Edited on 12/7/06 by Dusty]
Danozeman
posted on 13/7/06 at 05:21 AM Reply With Quote
Is there any play on the release brg?? If its sitting hard against the clutch all the time itl wear out the clutch quickly.
Dan
