donut
posted on 16/7/06 at 10:13 AM |
Diff noise
When out in my Indy i can hear the diff. Bit hard to explain but it sounds fine, no grinding, no clonking just the whuring of gears. The reason for
asking is that i'm a bit worried that it may be a duff one. Yes it has oil in it and fresh oil at that. It is reasonably loud-ish but not
annoying and not noticable over about 45-50mph because of wind noise.
Can you lot hear your diff whuring away? Should i be concerned?
BTW, it's an LSD diff.
[Edited on 16/7/06 by donut]
APR
posted on 16/7/06 at 11:35 AM |
can hear mine as well, they all make a noise. should be fine
Danozeman
posted on 16/7/06 at 11:51 AM |
In a normal car your inside it so wouldnt hear it. Your ears are kinda next to it in a locost so you will hear it if that makes sense..
Nothing to worry about. Not unless its starts whining like a bastid..
Dan
Deckman001
posted on 16/7/06 at 12:14 PM |
Told ya
Jason
donut
posted on 16/7/06 at 12:18 PM |
GREAT!! thanks, that's what i thought and hoped for.
Yes Jason, I know... i should listen to you more often!!
posted on 16/7/06 at 12:22 PM |
I am also glad to hear that - I've been wondering about the noise from my diff as well...
donut
posted on 16/7/06 at 12:55 PM |
Cheers Hicost, i'll get some Active 8 and pop some in just to ease my mind. If the V8 goes in i'll look at getting the diff either
reconditioned or replaced.
donut
posted on 16/7/06 at 01:02 PM |
sweet!! cheers!
donut
posted on 16/7/06 at 01:17 PM |
Right oh matey!!
Surrey Dave
posted on 16/7/06 at 03:43 PM |
I can here my Escort diff (sort of shushing noise!) , but I've wondered if the Indy type arrangement would be noisy as the diff is soldly
bolted to the chassis just near your elbow with no flexibility to take out noise and vibration
donut
posted on 16/7/06 at 08:05 PM |
Nail on the head there Dave!!
You're right about the solid mount too so i'm not worried anymore. If it starts grinding or banging i'll start to panic!!
Also i remember hearing your diff when out in your car last!
posted on 17/7/06 at 09:11 AM |
Dont use Active 8 on a LSD it will stop the LSD working.
Just leave it till you need to change it.
That is only true for a plate type diff. The Sierra LSD is a viscous unit that is sealed from the oil inside the diff housing, so it doesn't
care what type of oil it's running in (though obviously the CWP and bearings will).
[Edited on 17/7/06 by MikeRJ]
BKLOCO
posted on 17/7/06 at 05:30 PM |
Every Sierra diff I've ever heard in a solid mount makes that "shushing" noise.
The mounting onto RHS "amplifies" the bearing/gear noise.
As you say: unless it starts graunching/grinding, ignore it.
NS Dev
posted on 19/7/06 at 12:28 PM |
A diff about to fail in a locost will make you stop, don't worry!!!!
Mechanical sympathy will kick in believe me!!!
donut
posted on 19/7/06 at 01:44 PM |
ta
