ditchlewis
posted on 6/8/06 at 08:31 PM |
Ball Joint nut stuck and it just turns
I've been removing the top wish bones and one of the joints is stuck. the nut on the bottom just turns.
I've used the splitter tool to apply pressure but it still turns.
what can i do?
do i have to cut the shaft above the mushroom?
Ditch
Danozeman
posted on 6/8/06 at 08:34 PM |
Have u got any big sliding grips??
If so try and hold them tight together to jam the taper while u undo.
Dan
ditchlewis
posted on 6/8/06 at 08:37 PM |
Would large G clamps work?
problem is that i've removed the wish bone and it is loose on the hub.
Ditch
DIY Si
I've found jacking the car up and removing this nut first is often best, or as said, clamping it in place.
ed_crouch
posted on 6/8/06 at 09:20 PM |
This is a real sod of a job!
you can do it like this. Buy a NUT splitter of the appropriate size to fit the thread of the balljoint taper. Basically you have to screw it into the
thread on the balljoint (damaging the thread), and counterhold the balljoint spindle with it, and undo the nut with a spanner. When the nut unscrews
far enough to interfere with the nut splitter, remove the nut splitter and clamp it above the nut, and spin the nut all the way off.
THIS WILL DAMAGE THE BALLJOINT THREAD, but sometimes theres bugger all else that works. I never found that clamping the taper back together gave
enough friction to remove stubborn nuts.
Ive got a set of draper ones, and they work quite well for that sort of job. Total shite for splitting nuts, but hey...
Hope this helps.
Ed.
P.S. I should add that if you are careful with the application of said nut splitter, you may not danage the thread significantly. Normally, its just a
bit of crap in the thread which means that the nut is just a little more than finger tight. So, if careful, the balljoint MAY live again!
P.P.S. I am assuming that you will be replacing the joint?
[Edited on 6/8/06 by ed_crouch]
I-iii-iii-iii-ts ME!
Hurrah.
www.wings-and-wheels.net
omega 24 v6
posted on 6/8/06 at 11:07 PM |
How about using a small ratchet strap and pulling the top bone down against the bottom bone. This will put the pressure back onto the balljoint and
lock it allowing you to remove the nut.
Gunner1
posted on 7/8/06 at 01:04 AM |
Couple of ideas
Try tapping the bottom of the ball joint to force it into the taper more, then a spritz of penetrating oil on the treads only,
Gently try turning the nut evenly using a box end wrench without breaking the bond in the taper.
Or/and instead of the penetrating oil, apply heat to the nut only before trying to turn it.
If you have overnight, try a bit of vinigar and water into the taper and leave it outside (rust happens), then repeat above as it will have a bit of
grit in there to hold the taper.
If that fails, give yourself a healthy dose of scotch, and use a hack saw, the problem will be resolved before you know it and you can move on....
Good luck!
Al
zetec7
posted on 7/8/06 at 06:57 AM |
Even penetrating oil may let it spin. Try spray brake cleaner - it will remove ALL traces of lubricants, and should give enough stick to let you undo
the nut. I've tried this twice, both times successful. If you have an impact wrench, use this at the same time. The sudden twisting (instead
of steady turning pressure) is often enough to spin the nut off....and doesn't damage the threads or the nut.
roadboy
posted on 7/8/06 at 08:30 AM |
Small angle grinder with cutting blade & chop the end off, fit new ball joint, job done.
HTH
Ian
Jude Performance Services
splitrivet
posted on 7/8/06 at 08:53 AM |
As Ed says use a nut splitter. but split the nut with it.
Bob
[Edited on 7/8/06 by splitrivet]
NS Dev
posted on 7/8/06 at 09:22 AM |
CAREFULLY hacksaw the nut downwards near to but not quite touching the threads. Do this in a couple of positions and then carefully chisel the
remnants of the nut off. This should leave the balljoint intact and just in need of a new nut.
ditchlewis
posted on 7/8/06 at 11:48 AM |
Unfortunatly the nut splitter idea is a bit of a non starter as the nut is up inside the mushroom insert that MK supply for the sierra upright. is it
possible to get a nut splitter with one open side, shaped like a capital G?
the ball joint is already ruined as the rubber seal has been mullered by me.
Looks like a hack saw then..
many thanks
Ditch
