ned
posted on 22/8/06 at 02:56 PM |
OT domestic central heating
Question probably for the plumbers of you out there, guessing this is quite a typical scenario..
Got a 2 bed semi, boiler is awkwardly positioned in the kitchen (low level) and the hot water tank is in a built in wardrobe in the main bedroom (gets
hot in there due to this) and pipes run at ceiling level boxed in half way round the house through front room and kitchen.
I want to move/replace (it is an old boiler) into the utility room (adjoining kitchen and outside/below bathroom upstairs) also thinking of replacing
with a combi boiler so as to get rid of the hot water tank, possibly asbestos tank in loft (well stop using, not remove/disturb due to cost!) and
remove all the horribly visible pipework (ie run the small runs to the rads under flooboards or just painted to blend into decor)
How much of this is it practical/sensible to do myself? (appreciate I need a corgi man to do the connection/ disconnection/ comission of the boiler)
but as far as pulling out all the old pipework and reworking runs of 15mm copper whats the norm? I've done washing machine/dishwasher, hot/cold,
sinks, outside taps and bits and pieces and would give most things a go but need to know where to draw the line of messup vs cost to put right!
Obviously down here in Surrey will be a bit pricier than norm but can anyone also hazard a guess at a ballpark cost and advise of a good place to look
up local plumbers (rather than just the yellow pages) as I don't know any - is somewhere like check a trade a good site to go on?
cheers,
Ned.
beware, I've got yellow skin
posted on 22/8/06 at 03:20 PM |
Ned,
I've had dodgy old back boilers replaced in both the houses I've bought. Like you I've tackled plumbing jobs like bathrooms,
kitchens and outside taps, but to be honest if I had to do it again, I'd probably pay again to have it done. The boiler manufacturer's
seem to demand qualified installation for the warranty etc.
Where you will save some money is doing all the prep and finish up work yourself (whic I'm sure you'd do anyway) and making sure you
don't get charged by the plumber for disposal of the old boiler and associated rubbish - take it to the tip yourself and take the copper tank to
the scrap man (get good money for them).
I've used a company called Northern Gas Heating twice now and they have done a good job for sensible money both times. They work all over the
country too.
HTH
Nick
Aboardman
posted on 22/8/06 at 03:24 PM |
i installed my heating system and was easy, however my house was empty as i was gutting it, and running copper pipes through floors is a pain, i would
recommend using modern plastic pipes which are very easy to install in existing floors. plus no joints to leak.
you could install all the radiators and pipes, plumb in cold water and just get someone to install the copper gas line.
but i did this myself and just got a plumber to make the final 2 connections and to gas line.
you just need to get the pipe sizes correct.
ned
posted on 22/8/06 at 03:34 PM |
Thanks for the link Nick, will check that one out. Once the ex has left (buying her out, paperwork signed today) then it'll only be me there so
I'm not too bothered about mess as long as i have a room to live out of and a working sink & toilet!
Not planning on replacing the radiators, doesn't seem any need but obviously depending on boiler type and location pipework will need rerouting
to suit the new system.
Ned.
Ferg
posted on 22/8/06 at 04:13 PM |
Make sure you are happy with the probable reduction in flow rate which a combination boiler WILL give (unless it's crap already!). This will
only be noticeable if you run a bath.
I really wouldn't use plastic pipes unless you absolutely have to. The fittings are questionable on ALL the systems I've seen. I'd
use copper EVEN at today's prices.
Make sure you only notch pipework in joists between 10-20% of the supported span and only on the top of the joist. You can drill, of course, IF you
use plastic, but I REALLY wouldn't.
posted on 22/8/06 at 04:16 PM |
Ned - I've done a few conversions from Tank to Combi and my own Combi to Combi and I have no previous experience. I used copper, no pre-leaded
joints to keep down cost and make a nicer cleaner joint. Don't use plastic they swell/contract and eventually leak, usually in the most
inaccesible of places... Even wired the boiler myself but got a Corgi guy to install and relocate the Gas piping. Everything was perfect he even
commented how good the soldering was... if anything happens to your boiler though as a result of your work you're shafted! Therefore I recommend
Worcester/Bosch boiler which are superb - avoid Vokera Comib's like the plague - they are cheap (read expensive to buy) Italian, sensor riddled,
poorly assembled, unreliable, cancer riddled piles of SH1TE!!! Only good for keeping the extortionately priced Engineer(s) (now don't get me
started) to mend constantly - when the bill hit £400 in two years it was time for it to go. Paid £800 for the Bosch and it's already saving me
money!
[Edited on 22-8-06 by Hellfire]
Aboardman
posted on 22/8/06 at 05:05 PM |
i only said used plastic if it is going to be a hassle to run pipes with in floor voids, if it is no hassle than use copper all the time.
here are some links to sizing the system
http://www.gasheating.co.uk/sizingthesystem.html
http://www.gasheating.co.uk/pipesizing.html
http://www.diydata.com/planning/ch_design/sizing_pipes.htm
posted on 22/8/06 at 05:42 PM |
plastic gets more tempting every day with copper so expensive. Its nice that it does gentle bends easily, but as already said, the fittings arent
great. I believe you can use proper compression fittings if you use inserts, if this is so then id do that. Just leave the floorboards up for a week
to ensure there are no leaks.
Its a wee easy job to do anyway, esp if theres no missus to nag and p!ss you off about the mess! lol
ned
posted on 22/8/06 at 05:45 PM |
unless I'm missing something persumably there's no reason why i can't reuse any decent lengths of copper to save buying new stuff or
is it a fals economy and best to weigh it in with the tank and buy new anyway?
cheers for the replies so far...
Ned.
posted on 22/8/06 at 05:54 PM |
make sure you clean any pipe you are reusing, you dont want to let the sludge build up.
Ferg
posted on 22/8/06 at 05:59 PM |
Yep. Re-use if you can.
The other problem with plastic pipe after it's inability to hold water with any regularity is it just looks shit.
Crap copperwork looks rough if it's not level or plumb and plastic just winds about all over the place.
People who actually care about these things then tend to convert to copper everywhere where you can see it and defeat the object.
907
posted on 22/8/06 at 06:04 PM |
Use 15mm stainless.
Just think of the money you'll save on paint.
theconrodkid
posted on 22/8/06 at 06:30 PM |
just burn some chavs for heat,do us all a favour
who cares who wins
pass the pork pies
Lawnmower
posted on 22/8/06 at 08:10 PM |
I wll probably be looking at a new boiler soon (goota sell my landy first - I may cry). the corgi feller who moved my gas pipe in kitchen reckoned on
about £1500 to replace my combi boiler. asked about moving it across the bathroom (to free up room for a free standing shower) he said would be a
PITA. didn't give a cost for that.
My Father in law had a whole house done (terraced) in lincoln about 2 year ago, cost about £3500.
British Gas have got an offer on. wifey contacted them for a quote, have not got back to us.
B&Q sell boilers for about £400, but apparantly these are a cheap european import, are crap, and do not meet current corgi regulaltions. the corgi
bloke said he, would not fit, and iff he did, would not carry a garantee.
A recurring name that people are sugesting is the worcester/bosch brand.
mistergrumpy
posted on 22/8/06 at 08:22 PM |
I used to be a plumber some time ago and don't get me wrong converting to a combi is a big, messy job but is do-able by yourself. A bit like
building your own chassis really to use a comparison. Trust me a lot of firms nowadays are using plastic but I think its a play off. It is a lot
quicker and they're generally on price work but copper does look better i.e. bend radii are better. I'm loath to agree with Hellfire that
you should just jump on and do it as judging by his build, he has quite a bit of talent (not brown nosing, just impressed ) I reckon though if you
are on your own and don't mind the mess then yeah give it a pop but just take your time. Good luck
posted on 22/8/06 at 09:03 PM |
British Gas did a new clean combi install in my house about 5 years ago for £1800.
Yes they brought all the gear plumbed it all in copper. All I had at the time was the gas meter in the porch.
£1800 for a new combi system, 6 rads in a 2 bedroom bungalow. It took them 2 days.
By comparison, last year I added an upstairs to the house, 2 more beds and another bathroom and it cost me over £1K to get 3 more rads and a bathroom
plumbed out. Plastic pipe in all the unseen places.
Years ago I installed a system myself in a house we were renevating. It was empty at the time.
Like others got the corgi man to connect and commision the boiler. We left the filling loop open to the mains overnight and got a fairly satisfactory
indication of no leaks after 12+ hours at 4 bar....
James
posted on 22/8/06 at 09:42 PM |
Close mate of mine is a plumber, reckoned about £1500 for a place slightly bigger than yours Ned.
He says stick with copper pipe! Says he hates plastic, it's a bodge and he doesn't trust it not to leak after 5 years!
So there you go!
James
- Muhammad Ali
SixedUp
posted on 23/8/06 at 12:33 AM |
9 months back I converted my house from gravity-fed to mains-pressure hot water. I kept the existing boiler (for now) but removed the cold water and
expansion tanks in the loft, and the hot water tank in the airing cupboard, replacing them all with a heat store in the loft. If you've not
heard of heat stores before, they're an interesting technology that has all the advantages of a combi boiler, and none of the disadvantages. I
have been deeply impressed - it's working very well for me so far
To make this happen I needed to do a *LOT* of replumbing over 3 floors, including directly connecting to the boiler, all in a single weekend. I used a
combination of copper and plastic piping, along with some high-end, and expensive push-fit connectors (Tectite, from Yorkshire Fittings). Having
always used solder fittings in the past, I was skeptical of the push-fit stuff, but it was every bit as good as claimed. I have 6bar of water pressure
at my house (think of a 200ft water tower in the back garden!), and have not had a single leak from the work I did. I reckon that using this new stuff
was 2-3 times faster than using solder joints; which may be one reason why plumbers on an hourly rate don't like it very much ...
The plastic pipe fits onto the pushfit connectors perfectly, using metal inserts to support the pipe. You can join plastic to copper like this. The
Tectite stuff comes with a 25year warranty when used according to their specifications (which I found reassuring).
I suspect that if you're fairly competent you ought to be able to plumb everything else up yourself, and just have the boiler
installed/comissioned by the Corgi man. Thats certainly what I'd aim to do ...
Richard
Marcus
posted on 23/8/06 at 08:42 AM |
Ok, I'm biassed, but plastic pipe systems are the way forward (unless running horizontal with insufficient pipe clips). I work in product
development for a plastic pipe and fitting manufacturer. Pipes and fittings are manufactured in our Doncaster plant to exacting standards. Suggestions
that 6 bar is in any way exceptional for a plastic pipe is laughable!
We test every production run of pipe and fitting (15mm) to 38 bar. The fittings do not leak. Just for fun, we sometimes blow the stuff up. Pressures
of 50 to 60 bar are needed, and this ruptures the pipe before the push fit fitting blows. 99.9% of faults reported are down to crap in the fittings.
Plumbers don't realise you have to be just as careful with plastic as you do when soldering copper.
The amount of fittings that are just thrown into toolboxes to be used later is frightening. If you open a bag of fittings, seal it to stop dust
getting in!
We regularly do factory visits for plumbers, and even the most diehard copper fan can be converted to plastic after seeing our test regime.
BTW we guarantee our product, if installed to our recommendations, for 50 years.
Sorry about the rant, BUT I believe in our product!!
Just to add, if you're installing a combi boiler, plumb the first metre or so in copper. If the water level is low in the heat exchanger and the
boiler is on full, as soon as the pump switches on, a shot of superheated water could damage the plastic pipe.
[Edited on 23/8/06 by Marcus]
Marcus
Because kits are for girls!!
posted on 23/8/06 at 10:54 AM |
I totaly agree, problems with new technologies are invariably down to useage and/or lack of understanding.
If it really was only good for 5 years, most of the manufacturers would be out of business already.
SixedUp
posted on 23/8/06 at 01:21 PM |
quote: Originally posted by Marcus
Suggestions that 6 bar is in any way exceptional for a plastic pipe is laughable!
The ones I used are rated at 9bar continuous use, presumably more for short times, and probably tested at similar pressures to what you are
describing.
Just for future reference, which manufacturer/fittings do you work on? If its not appropriate on the forum, drop me an U2U, as I'd like to tuck
it away for future reference, thanks.
quote: Sorry about the rant, BUT I believe in our product!!
Well, using it certainly converted me. The push-fit connectors in particular are a joy to use, especially in tight corners, and the flexibility of the
plastic pipe was very helpful. I think I'd still use copper for surface runs though, as it does look a lot neater (the 22mm plastic pipe I used
was off a reel, and impossible to get completely straight, even with a lot of clips).
Richard
ned
posted on 23/8/06 at 01:51 PM |
Been looking at boilers online, seeing as I'd heard of worcester before (the only one i'd heard of before) and they appear to be
worcester-bosch I think thats a brand I'd trust and I'm guessing they are nearer the top/better quality end of the market - don't
want to be farting about with some cheap rubbishy thing.
Looking at the worcester bosch site the 'find a boiler' part of the site is recommending a greenstar 25cdi or 24i junior. Anyone care to
comment on these two machines? The latter seems to be 20kg lighter, £150 cheaper and I can't see much difference in the technical specs, anyone
care to comment on that either?
details here:
http://www.worcester-bosch.co.uk/index.php?fuseaction=product.techdata&con_id=127777
and here:
http://www.worcester-bosch.co.uk/index.php?fuseaction=product.techdata&con_id=125926
repsectively
I've checked out the documentation/installation notes and all seems relatively straight forward pending finding a man to do the gas work.
cheers,
Ned.
Surrey Dave
posted on 23/8/06 at 04:55 PM |
I posted about this before , I'd be interested if you find someone to commision the boiler , I reckon the rest aint too difficult.
posted on 23/8/06 at 04:56 PM |
how much are they ned?
if anyone in leeds or nearby needs one doing, my mate will probably sort it nice and cheap.
[Edited on 23/8/06 by JoelP]
ned
posted on 23/8/06 at 06:02 PM |
without trawling all the sites again I think the cheapest I saw the 25cdi was about £860 and the 24i junior £720odd (inc vat) you then have to add
whichever programmer (wireless programmable stat jobbie from about £50) and any additional flue bits.
I discovered this afternoon a work colleague who has had a 35cdi installed a couple of months back (very happy customer, had a problem with it but
couldn't fault their after sales/warranty) and another forum member has told me of another locoster who might be able to help with the gas
My colleague tells me he's friends with his plumber now so might be able to get me a trade price aswell
Ned.
[Edited on 23/8/06 by ned]
