Author: Subject: alloy wishbones
ettore bugatti
posted on 5/9/06 at 07:12 PM Reply With Quote
alloy wishbones
Has somebody here constructed their wishbones from aluminium tubes?
It should be a good option, I think.
It lowers the unsprung weight even when increasing the tube diametre and thickness and doesn't rust.
I cannot find any info on this forum about this. Which seems strange since almost every month questions are raised about alloy spaceframes.
nitram38
posted on 5/9/06 at 07:27 PM Reply With Quote
Bad idea.
Aluminium has a tendancy to fracture, so most aluminium suspension parts are castings.
Tubular chassis would have the same problem. That is why the elise/renault spyder/vx220 are made in a monocoque design.
t.j.
posted on 5/9/06 at 07:30 PM Reply With Quote
I can't weld it at home, and even when i would not make any suspension-parts of it due the cracks which prob. will occur.
posted on 5/9/06 at 09:51 PM Reply With Quote
Ally or alloy? Totally different things...
assuming ally.... work and age hardening, and stress fracturing, are the problems.
I wouldnt say its impossible to make a bone that would last and be lighter, but it would take research and testing to be sure.
At least with steel arms, if it last a week, its likely it will last a year. With ally, you would have to life the parts.
chrisf
posted on 5/9/06 at 10:31 PM Reply With Quote
I considered having a go at using 6061-T6 for the upper front wishbone.
--Chris
Gunner1
posted on 6/9/06 at 04:01 AM Reply With Quote
I did not go with aluminum for the bottom wishbones as this is what takes most of the shock and stress. Instead made up some out of 1" dom. The top however does not take so much stress and I went with an "off the shelf" item from "Joe's Racing" in Washington State. Very light piece, especially when used with monoball upper ball joint. This upper arm is a Mustang design and provides full adjustability along with great quality control on the construction. (They arrive powder coated too)
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 6/9/06 at 04:38 AM Reply With Quote
Aluminium
The problem with aluminium is it is a specialist material. Properly designed, manufactured, installed and inspected they will be fine. However I think that is beyond most of us and not low cost.
I did see some neat ones when I was judging formula student. Basically machined ends with aluminium tubes Loctited onto the stubs. Its very simple to replace tubes and as there is no welding no heat related problems.
For the rest of us stick to CDS.
John
bimbleuk
posted on 6/9/06 at 07:46 AM Reply With Quote
Even Lotus didn't get it quite right. The original Elise uprights were made from extruded alluminium. Fine for road use but on track with slick/semi-slicks the lower ball joint mounting point cracks. They replaced them with steel uprights which were lighter and stronger.
posted on 6/9/06 at 08:38 AM Reply With Quote
The Elise uprights even look ultra flimsy, doesn't surprise me that they fail under duress.
Note that even the Elise uses steel wishbones! I don't think there is a huge amount to be saved in terms of unsprung weight over a decently made steel wishbone, especialy as not all of the wishbone is unsprung.
ettore bugatti
posted on 6/9/06 at 09:17 PM Reply With Quote
Thanks for your replies.
But wasn't aluminum more ductile and more elastic them steel?
chrisf
posted on 6/9/06 at 11:00 PM Reply With Quote
This honestly might fall into the "Why Bother?" category. I think I'm just going to go with the tried and tested steel arms.
--Chris
nitram38
posted on 7/9/06 at 03:13 AM Reply With Quote
Aluminium is less dense than steel. In other words there are bigger gaps between the molecules. This might make it lighter but also makes it weaker as the bonds between the molecules are much weaker. Aluminium parts tend to be thicker than there steel counterparts.
Wile I have seen aluminium used on race cars etc, they are also the first bits to break.
Stick with steel. The 0.00001 mph you gan, will not be worth the extra cost or hassle.
Syd Bridge
posted on 7/9/06 at 08:41 AM Reply With Quote
So, all you people wouldn't use aluminium for suspension components!
That's a quantum change after what was said in defence of a certain manufacturer trying to sell those untested aluminium things not so long back.
I notice he has wisely deleted the thread now.
Yes, the alu will fail due to the ageing process and brittle fracture. The parts I deal with regularly are lifed. Some as little as 60km, depending on road surface, then destroyed immediately after removal.
I'll repeat: for an aluminium part to be as safe as a steel part for road use in similar applications, it will end up heavier and far bulkier. This is due to the need to design for ageing and impact resistance. All that said, the parts would still have a finite life far shorter than steel.
Syd.
