posted on 2/1/07 at 07:49 PM |
1986 XR4x4 Diff??
Anyone confirm the diff in the back of a 1986 XR4X4? It has a 2.8 engine.
7", 3.62 LSD, disc brakes?????
[Edited on 2/1/07 by coozer]
hector
posted on 2/1/07 at 08:08 PM |
Yea sounds right, thats what mine was!
Pezza
posted on 2/1/07 at 09:15 PM |
Pretty sure all 4x4's had lsd's
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one
portion of chicken tikka pwnsala and the obligatory free pwnpadom.
RichieC
posted on 3/1/07 at 01:32 AM |
Definately a 3.62 LSD. Discs as far as I can remember.
Rich
NS Dev
posted on 3/1/07 at 08:00 AM |
yep, exactly right
Syd Bridge
posted on 3/1/07 at 09:08 AM |
And I've had at least three Sierra 4x4's through my hands, and still got the remains of one mounted in a car out the back......
3.62, and 7 1/2". YES, 7 1/2"!!!!!
Not all 4x4's were 7", and to the contrary, most were 7 1/2" up to the late 80's. At least those behind the 2.8 engines.
Syd. ![](/images//smilies/smile.gif)
NS Dev
posted on 3/1/07 at 09:52 AM |
this is where I get muddled up!
Is that the Crownwheel bolt pcd or the casing width?
Ford call the 7" diff that because of its crownwheel pcd, just wondering if we muddle things on here by talking about casing widths??
I have had 6 ford lsd's from xr4x4's, 4x4 estates and a cosworth, and all had 7" crownwheel pcd's, but i've never
measured the casing so no idea what widths they were, other than they were all the same as I've never altered my diff mount jig which I made to
fit the first one, which was a 1987 vintage one!
Syd Bridge
posted on 3/1/07 at 10:05 AM |
That's cwp's, Nat.
Ford put them in that bigger case for good reason.
Syd.
[Edited on 3/1/07 by Syd Bridge]
NS Dev
posted on 3/1/07 at 10:08 AM |
fair point!
Liam
posted on 3/1/07 at 06:30 PM |
You sure about this, syd??
I've had many 4x4s pass through my hands, including 2.8, 2.9, 2.0 DOHC and cosworth; saloon, estate and granada. All have been 7".
I've also never, ever, ever heard of any of the many locosters who've bought themselves a 4x4 back axle for its LSD ending up with a
7.5", which you'd expect to find if most older ones were 7.5".
There is also the fact that the 7.5" comes in 3.64 as opposed to the 3.62 of the 7", if i'm not mistaken. Not a huge difference but
probably enough to upset the centre diff VC if a 3.64 is run with the 3.62 front diff. Certainly not a design choice the factory would make
anyway.
I think if you've come accross a 4x4 with a 7.5" rear diff it's much more likely to be a later addition than a factory fit.
Liam
paulf
posted on 3/1/07 at 07:36 PM |
ive come across a 2 litre 4x4 and am considering getting the diff, will it definitely be a LSD? and I assume a 3.62 ratio.
If so how suitable is the lsd set up for a lighter car like a seven? I am thinking of using it with a dedion axle.
Paul.
Liam
posted on 3/1/07 at 07:52 PM |
2 litre 4x4 will be a 3.92. Deffo a 7" LSD though. Have a search for the many threads on the pros and cons of LSDs. Dont have experience of
one in a seven myself.
Liam
NS Dev
posted on 4/1/07 at 08:45 AM |
anyway.
Liam
thinking about it surely the flanges would need a swap as well if std 4x4 rear hubs were used as the CV joints are larger and the lobro joint bolt pcd
is bigger.
Syd Bridge
posted on 4/1/07 at 09:49 AM |
Liam
Yes, quite sure. I even crawled under the one still here and checked last night. The reason I know it initially was a 7 1/2", is that I had to
alter the chassis from the 7" fittings, to widen the mounts to get it in. Not just the bolt fittings, but the whole chassis assembly. Meant
slightly shorter wishbones as well, to compensate.
The one here came out of a 'c' reg 4x4 ghia, with a 2.8. Also has the bigger cv's. The couple I had before it were also behind
2.8's, and 'c' and 'd' reg. And all lsd's as in the Scorpio's.
I know that when Ford went to the 2.0l dohc for the 4x4, the rear ends then went to 7" for all 4x4's. Up to then, it seems that it was
'mix and match'.
Syd.
[Edited on 4/1/07 by Syd Bridge]
