Poll: Reverse box [View Results]
Quaife
Other
None
<<  1    2  >>
Author: Subject: Reverse box
millemg
posted on 4/1/07 at 10:26 PM Reply With Quote
Reverse box
Who would go for Reverse or not bother ?
[Edited on 4/1/07 by millemg]
G.Man
posted on 4/1/07 at 10:31 PM Reply With Quote
worthless poll..
The scrimpers will say none, the people will need it will say yes, and the money no object will say quaiffe..
Opinions are like backsides..
millemg
posted on 4/1/07 at 10:32 PM Reply With Quote
Damn, worth a try
No need for reverse on a BEC unless it's an absolute necessity...........
Phil
millemg
posted on 4/1/07 at 10:33 PM Reply With Quote
Phil
I like that reply
G.Man
posted on 4/1/07 at 10:37 PM Reply With Quote
Phil
I like that reply
as long as you are happy looking a twunt when you find out you do need it and havent got it
millemg
Phil
I like that reply
Ohhh you spoiled it
Is it really, really worth £700 and the whine and oil leaks ?
G.Man
posted on 4/1/07 at 10:41 PM Reply With Quote
Yup..
i have been caught short a few times that would have meant getting out and struggling to push it uphill backwards...
and the whine isnt bad, the exhaust more than drowns it out.. as for oil leaks, wot oil leaks... speak to Marc...
McLannahan
posted on 4/1/07 at 10:42 PM Reply With Quote
I don't miss having one! I quite like the fast that I push into parking spaces when needed. More than often I'll park so I can drive out forwards anyway.
Only slight pain (and it's outweighed by the cost, weight ) factor is pushing KC back into the car port...which has been cleverly designed not wide enough to get into.
Ditch it I say! Spend the money on making the car yet lighter still!
In conclusion I vote for the monster raving loony party.
millemg
posted on 4/1/07 at 10:43 PM Reply With Quote
Yup..
It's very flat where I live.
G.Man
posted on 4/1/07 at 10:48 PM Reply With Quote
Yup..
you are trying to convince yourself not to, so don't..
posted on 4/1/07 at 11:07 PM Reply With Quote
There has only ever been one time in the last three years, when I noticed a lack of reverse gear and for a split second wished I had one. I was driving alone and took a wrong turn down a one way street. Having reached the end, I needed to do a three point turn in front of quite a few bystanders and didn't relish the thought of having to get out and push, so I reached out of the car, put my hand on the road and with quite a bit of effort managed to push myself far enough back to complete the manoeuvre.
The strain on my face would have been quite amusing but fortunately I had my helmet on and kept the visor down.
Phil
zxrlocost
posted on 4/1/07 at 11:12 PM Reply With Quote
never needed one plan ahead
if you do and people are watching they wont be laughing when they see how fast it moves forward
tom windmill
posted on 4/1/07 at 11:40 PM Reply With Quote
agreed!!!
skydivepaul
posted on 5/1/07 at 12:23 AM Reply With Quote
if you do need to turn round quickly and you are not shy or retiring
apply full lock in either right or left hand
apply 10,000 rpm
dump clutch
= 180 degree turn
easy done and you have saved £700.00 on a weight gaining reverse box.
spend the money you have saved on beer and carbon fibre bits to make your car even lighter
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
robby
posted on 5/1/07 at 08:20 AM Reply With Quote
faster forward, don't worry about going backward! (and i'm surrounded by mountains... )
mad dad
posted on 5/1/07 at 08:25 AM Reply With Quote
never found the lack of reverse a problem don't normally go out in it to park and when i do as has been said just apply a bit of planning - no prob
Gergely
posted on 5/1/07 at 09:48 AM Reply With Quote
My concern would be how to get back to my garage which has a long (50m) driveway and the end slopes downwards to the garage. If I go forward towards the garage, I won't be able to push the car out. If I want to reverse into the garage, I have to push it backwards all the way and somehow brake it when on the slope... Not sure. I wouldn't want a reverse, but I am also hesitationg now...
smart51
posted on 5/1/07 at 10:03 AM Reply With Quote
I don't have one and only once have needed one. I drive forwards into my garage and push it out backwards. It just so happens that this is slightly down hill. I rarely use car parks and in any case most allow you to drive through to the next isle. I often park facing up hill if I can.
The only time I needed a reverse was on a narrow lane that had a ford. In the end, I just went through the water.
the_fbi
posted on 5/1/07 at 10:48 AM Reply With Quote
You need one (or a powered means of reversing) if you are going to race in the 750mc.
cloudy
posted on 5/1/07 at 11:13 AM Reply With Quote
I say reverse is against both the kit car and locost spirit! don't have one!
James
andyd
posted on 5/1/07 at 11:27 AM Reply With Quote
Rig up an electric reverse that you can take in and out of the drivetrain. No loss of power, no shakes and rattles and if you're really clever you could make it so the throttle pedal operates the speed (of the electric motor) when reverse is engaged. It'd just be like a "real" car then!
As an aside though and kind of on topic... has anyone had any experience of Quaife's all in one chain driven diff? I believe that has a reverse gear built in too.
tks
posted on 5/1/07 at 11:47 AM Reply With Quote
pushing... it just looks stupid..
also legalisation is a isue...
I'm finishing my electric reverse wich works just like in the normal car.
its true that its a couple of KG but hey
for daily use **ck those kG not?
it just means the driver weighs to much when talking abut weight..
Tks
p.d. search for my thread
pdw709
posted on 5/1/07 at 12:57 PM Reply With Quote
I've got one and I use it all the time getting the car in/out of the garage.
It all depends on the type of driveway /garage layout that you have.
Having said that, I have had to use it on more than one occasion when out and about, expecially when in town.
Personally I could't live without one.....
d8mok
posted on 5/1/07 at 01:15 PM Reply With Quote
i've currenly got 1 and i'm considering taking it off. Any idea what its worth??
and what will i need to replace it?? is it just a new full length prop??
cheers
<<  1    2  >>
