Author: Subject: Cleaning Expansion bottle
RichardK
posted on 11/2/07 at 07:15 PM Reply With Quote
Has anybody got any tips as to how to clean the inside of my expansion tank, it's off a VW and has a fine mesh type filter thing inside so can't physically get in it. Thinking of a bleach type of mixture or a bottle of Cillit bang in there.
Thanks in advance.
Rich
Gallery updated 11/01/2011
gregs
posted on 11/2/07 at 07:29 PM Reply With Quote
caustic soda - but don't get it on you....
locoboy
posted on 11/2/07 at 07:30 PM Reply With Quote
Rip out the filter!
No other expansion bottle i know of has a filter and its not going back in the VW so why do you need it?
Once removed get some gravel in there and experiment with cleaning agents.
Locoboy
Donners90
posted on 11/2/07 at 07:42 PM Reply With Quote
Bleach
Did it for me. Make up a strong solution and keep turning the reservoir to ensure all surfaces for about 30 mins or so. Remember to block up all holes or you'll cover yourself in bleach !!!!
givemethebighammer
posted on 11/2/07 at 08:23 PM Reply With Quote
dishwasher powder works pretty well.
RichardK
posted on 11/2/07 at 08:46 PM Reply With Quote
Cheers guys, tried Bleach, no good, trying washing soda as I had some left over from the electrolsis thingy, if that doesn't work will try the caustic soda thing, just a bit worried that the causic soda would melt the bottle or something equally awful
Rich
posted on 11/2/07 at 09:17 PM Reply With Quote
Dishwasher powder worked well for mine and is also very good for getting oil from a cooling system after head gasket failed and filled system with oil . Everything else I tried failed
UncleFista
posted on 11/2/07 at 09:20 PM Reply With Quote
Hot water, squirt of washing-up liquid, and a handfull of sharp sand.
Shake it all up and Voila !
Tony Bond / UncleFista
RichardK
posted on 11/2/07 at 10:05 PM Reply With Quote
Due to this seemingly integral filter thing I can't use gravel or sand which would have been nice and easy.
Ok so I'll try my dishwashers powder next, her blusher or foundation?
Retreats & ducks for cover
Rich
[Edited on 11/2/07 by RichardK]
robertst
posted on 11/2/07 at 11:09 PM Reply With Quote
i've tried dishwasher powder, caustic soda, bleach, turpentine, sand, gravel, little stones (basically gravel), and even industrial paint stripper (left me groggy for at leat two days). nothing has worked.
except the old toothbrush... found out the only way for me was to get a really long, flexible spatula and carve the grime off the bottle...
oh and forget about making it white and shiny again...
[Edited on 11/2/07 by robertst]
Tom
designer
posted on 12/2/07 at 07:59 AM Reply With Quote
Try soaking in Bruclens used by home brewers to clean/sterilise bottles and tubs.
posted on 12/2/07 at 08:30 AM Reply With Quote
I soaked mine in Arial soap powder...
posted on 12/2/07 at 08:51 AM Reply With Quote
if shaking the hell out of it with fine gravel inside makes no difference, it may be the plastic has been discoloured so nothing will change that.
any crud on the surface would have been removed by gravel striking it.
Phil.J
posted on 12/2/07 at 08:54 AM Reply With Quote
Don't know about expansion bottle, but either you are enormous or you have a very small house!
Lightning
posted on 12/2/07 at 09:05 AM Reply With Quote
Arial soap powder for me too. Worked a treat.
zetec7
posted on 12/2/07 at 09:11 AM Reply With Quote
Got access to someone with a pressure steam cleaner? That'll clean the crud off it (after all, it cleans grimy engine blocks back to shiny!). Stick the end of the wand in there, give it a shot for a minute, rinse, and voila!
http://www.freewebs.com/zetec7/
gottabedone
posted on 19/2/07 at 05:58 PM Reply With Quote
Is the crud the normal red/brown rusty deposit that gathers with age? If so try sticking a long piece of wire in the end of your drill. Put a loop on the other end and a piece of cloth through it. You can then agitate your detergent. Worked for me - oh and i put it in the dishwasher but don't tell!!!!!!!!!!!!
