posted on 1/4/07 at 02:59 PM |
Fitment Problems
Well, my build was cracking on at blistering place until.... it snowed and was too cold.
With the weather warming up now I want to get going again but I'm bugged with some problems.
The steering shaft runs right across the middle of the oil filter and I'm stumped! I only have 45mm of clearance here and its pi€€ing me off.
There's a picture on my blog.
I now find there isn't room for the alternator either so thats more thinking that I didn't bank on at the start.
I cant move the engine anywhere as its such a tight fit with chassis rails in the way.
Anyone else had this problem fitting a zedec in a Vortx??
nitram38
posted on 1/4/07 at 03:11 PM |
I haven't built a 7 but you can by a remote filter and use a sandwich take off.
It will need a bit of plumbing. Lots of builders move their alternator or use a smaller one.
Do a search...........seek and ye will find!!![](/images//smilies/bigsmile.gif)
westf27
posted on 1/4/07 at 03:12 PM |
Deepest sympathy
Is there a smaller filter which would fit.My mr2 roadster has filter half that length.There are smaller alternators around which may help together
with different fan belt.Dont know how good your kit manufacturer is they help.All sounds familiar in this crazy world of car building.Good luck
555
theconrodkid
posted on 1/4/07 at 04:00 PM |
renault 5 turdo filter is smaller than a small thing on a cold night,most people use it
who cares who wins
pass the pork pies
Krismc
posted on 1/4/07 at 04:05 PM |
yea me, its a tight bloody fir, i used a fiesta filter and cost me £4 its about 2"-3" long
tom_loughlin
posted on 1/4/07 at 04:40 PM |
I have just taken my filter off my zetec...Its from some renault.... I can get part No if you like?
It's about 35mm long, and clears the steering shaft by 6ish mm.
Hope to help
Tom
posted on 1/4/07 at 05:09 PM |
Cheers chaps, Ive got about 42mm at the shortest bit so a 35mm should be ok.
Is the part number FRAM PH2874??
Chris, what are doing with your spare 2.0 engine??
Guinness
posted on 1/4/07 at 06:20 PM |
Go left hand drive?
Mike
marc n
posted on 1/4/07 at 06:33 PM |
fiesta oil filter or mr2 i believe
alternatorwise you need a different bracket
cheers
marc
please email rather than u2u
chrismnrltd@btinternet.com
posted on 2/4/07 at 07:27 AM |
Cheers Mike, hadn't thought of that one! In a rash moment of thinking I reckon shortening the steering shaft and lengthening the triangular
shaft on the steering column, thats easy because the column adjusts in and out.
That will move the centre of the top UJ down and away from the engine. That may give me some extra room to get a take off plate in.
Failing that tap the casting on the oil pump housing and fit 45 degree unions.
May be easier to go LHD though.....
posted on 5/4/07 at 06:58 PM |
and the problems rumble on... ![](/images//smilies/sad.gif) ![](/images//smilies/sad.gif) ![](/images//smilies/sad.gif)
blog updated!
amalyos
posted on 5/4/07 at 07:13 PM |
U2U Numnuts AKA Dion.
He fitted a 2lt Zetec into an MNR, I know he had some problems, he may be able to help.
Good luck
http://stevembuild.blogspot.com
numnuts
posted on 5/4/07 at 09:11 PM |
Hi i know how you feel, i have had all the same issues as you and more please u2u me i will help as much as i can . By the way the toyota mr2 oil
filter will clear i have a cooper part No if rqd .
Agriv8
posted on 5/4/07 at 10:32 PM |
are you drum on the rear ?
The flexis are deigned for the disks so from the little I can see in the picture are too long.
A well place P clip may allow for enough travel and keep the hose away from the wheel.
Keep us updated regarding the enthusiam todays wonderfull weather has had me back in the garage tinkering with my efi.
REgards
Agriv8
chockymonster
posted on 5/4/07 at 11:23 PM |
To sort the brake pipe out use the natural bend in the pipe.
Slacken the flexi where it joins the bodywork.
Then twist the flexi to bend it away from the wheel, once it is in a position where it will not touch the wheel do the nut back up to hold it in
place.
RichieC
posted on 6/4/07 at 12:07 PM |
Exactly what he says
Im also running drums and needed a slight "twist" in the hose to prevent it fouling.
You can see what I mean from the reflection in the bodywork, just rotating the end where it joins the body, prior to fitting the nut, is enough to
kink the flexi out of the way.
Rich
![](/galpreviews/a535564-Flexi.JPG) ![Rescued attachment Flexi.JPG](/gallery/a535564-Flexi.JPG) Rescued attachment Flexi.JPG
marc n
posted on 6/4/07 at 01:48 PM |
are you on drums too Rich ???
i ask as we have never had the flexi problem till now, but as far as im aware you two guys are the onlty ones on drums, so may be worth looking into
for future referance asking if people are fitting drums or discs on the rear
cheers
marc
posted on 6/4/07 at 02:47 PM |
I tried twisting the hose but it slowly arched up and close to teh tyre again. As the wheels I'm using at the moment are off the donor when I get
some bling ones they will be a little wider.
I've put a bracket on the inside so its well out of the way.
Marc, what do you think about it? Worth putting a bracket on the chassis?
[Edited on 6/4/07 by coozer]
![](/galpreviews/a535615-Brake Hose Bracket.JPG) ![Rescued attachment Brake Hose Bracket.JPG](/gallery/a535615-Brake Hose Bracket.JPG) Rescued attachment Brake Hose Bracket.JPG
RichieC
posted on 6/4/07 at 03:38 PM |
Hi Marc, yes mate Im on drums too. Wasnt a problem for my fitment, just needed the wee twist.
I note however though that Coozer is using a bracket so the join between flexi and copper pipe is vertical, mine just joins on the inside of the arch.
Also, you have youre back plates the opposite way around to mine, ie with the master cylinder at the front of the disc, mine are at the rear, hence no
worries.
Regards
Richie
PS Marc I think my scuttle should be collected from you guys if not today then over the weekend.
Krismc
posted on 6/4/07 at 03:41 PM |
quote: Chris, what are doing with your spare 2.0 engine??
It went walkies, £900 on ebay (it was brand new) id have loved to hold onto it but just bought a 20k audi so im a little skint
posted on 6/4/07 at 04:25 PM |
quote: I note however though that Coozer is using a bracket so the join between flexi and copper pipe is vertical, mine just joins on the inside of
the arch. Also, you have youre back plates the opposite way around to mine, ie with the master cylinder at the front of the disc, mine are at the
rear, hence no worries.
Negative negative The back plates only fit one way and the cylinder is at the back![](/images//smilies/bigsmile.gif)
RichieC
posted on 6/4/07 at 05:02 PM |
Oh yep I see. I did wonder how youd managed that!!
Fairly sure though that having the joint between flexi and microbore horizontal would help the situation, certainly no problems with impinging on
wheels with mine.
Rgds
RC
[Edited on 6/4/07 by RichieC]
