Author: Subject: masking a axle up proir to painting
d8mok
posted on 27/4/07 at 12:37 PM Reply With Quote
i'm having my back axle powder coated on wednesday. I've made some steel plates that bolt over each end and over the diff and used cardboard as a gasket so nothing can get in.
one question is what to do with the breather?
and does shot blasting and powder coating damage any exposed threads?
cheers guys
mookaloid
posted on 27/4/07 at 01:11 PM Reply With Quote
You should definitely plug the breather to stop sand/grit getting in although you would be best to clean it out afterwards as some may still get in somewhere.
Threads can be damaged by blasting depending on the media being used. Powder coating will clog up any threads so unless you want to run a tap down them afterwards you should protect them with old bolts etc.
I would drain any oil out first too.
Mark
Mr Whippy
posted on 27/4/07 at 01:29 PM Reply With Quote
why not tap & plug the breather and put old bolts in to the open threads.
[Edited on 27/4/07 by Mr Whippy]
posted on 27/4/07 at 07:00 PM Reply With Quote
Which type of axle ? --- if it is an English axle be aware that in places the casing can get paper thin due to corrosion.
d8mok
posted on 28/4/07 at 02:04 PM Reply With Quote
yeh its a english axle. is it a problem?
