Author: Subject: Megasquirt Map
prelude1980
posted on 24/7/07 at 07:51 AM Reply With Quote
Megasquirt Map
I need some help with my map.
The engine is a 2 litre blacktop with GSXR 600 throttlebodies and injectors with EDIS.
Can somebody cast an eye over my settings please as there is something.
matt_claydon
posted on 24/7/07 at 11:13 AM Reply With Quote
What problmes are you having?
prelude1980
posted on 24/7/07 at 12:08 PM Reply With Quote
mainly seems to be overfuelling, but i mean to the extent of flooding the cylinders
TangoMan
posted on 24/7/07 at 06:42 PM Reply With Quote
I tried looking at it for you but gave up. If I try to download it it comes up as an XML file. If I copy the text and save as an MSq then it has garbage values in fuel req etc.
If you attach a downloadable file I will have a look. A datalog would also be sensible if you want answers to what is going wrong!!
Summer's here!!!!
prelude1980
posted on 25/7/07 at 07:36 AM Reply With Quote
managed to get it running of sorts, i found a problem the injectors seem to keep going into test mode, no matter how many times i set it in normal mode and burn to ecu. I will get my adjusted map and datalog on later when i remember to turn the datalogging on
tks
posted on 26/7/07 at 03:58 PM Reply With Quote
try before posting zipping or rarring the file it will help fooling the file/download/browse system
Tks
