Avoneer
posted on 8/8/07 at 05:33 PM |
Yoko Tyres Red Spot
Does it go on the inside or outside?
Pat...
carlgeldard
posted on 8/8/07 at 05:37 PM |
Pat
The tyres will be directional so the spots will got to the left or right side of the car. Sorry I don't know which side.
Carl
higgsti
posted on 8/8/07 at 05:39 PM |
if there directional ie 48s it will say which direction they should be put in.the spots on side are usually to match up with spots on rims of new cars
so the tyre and wheel are balanced .why its not on all rims i dont know .the dot is usually on the outside but check direction arrrow of tread
posted on 8/8/07 at 05:47 PM |
On bike tyres the dot lines up with the valve to give the best balance option so you don't need so many weights. There should be an arrow for
rotation shouldn't there?
Dusty
posted on 8/8/07 at 06:18 PM |
Red dot usually marks the high point of the tread and there may be a rim mark on the wheel which marks the low point. These are best aligned. Yellow
dot is lightest point on the tyre and should be lined up with valve. If both dots present red dot takes precedence (assuming the rim is marked).
caber
posted on 8/8/07 at 06:43 PM |
spots on outside so you can see them when the wheel is on the car!
caber
TangoMan
posted on 9/8/07 at 10:06 AM |
Jus wot ee sed!!!!
Summer's here!!!!
