Author: Subject: What charger for Odyssey battery?
TimC
posted on 14/8/07 at 08:05 AM Reply With Quote
Hi
I've got a tine Odyssey PC310 and I want a drip Optimate-type charger for it. Should I get one for a bike battery or one for a car battery?
A Nonny Mouse
posted on 14/8/07 at 08:10 AM Reply With Quote
Isn't it a 12Volt Battery, despite it's gel like innerds??? If so the normal Optimate should be fine... I would of thunked.
procomp
posted on 14/8/07 at 08:31 AM Reply With Quote
Hi Tim. As said ^^ they do not require a trickle charger like the redtop ones.
cheers matt
v8kid
posted on 14/8/07 at 10:15 AM Reply With Quote
These things require a hefty charge rate to fully charge them - from memory its around 20A. once the voltage reaches a certain limit - again from memory its around 14.5 volts the charge rate has to drop off substancially or the battery gets knackered.
If you charge at less than optimum the battery does not get a full charge. No problem if you have a standard duty alternator fitted as it will top it up at a good rate.
I have the same problem and am baulking at paying inflated prices for "automatic" chargers that don't specify the output characteristics
stevebubs
posted on 14/8/07 at 11:03 AM Reply With Quote
Optimate or Accumate. Either will work fine.
[Edited on 14/8/07 by stevebubs]
