Blacktop
posted on 29/11/07 at 10:33 AM |
Painting fibreglass
Found this article while browsing the web. Seems like a cheap & easy way to paint a kit car.
Anyone done this before and what were the results like?
http://www.paintsystem.blogspot.com/
smart51
posted on 29/11/07 at 11:12 AM |
It looks great. What is it? The deauville cars website doesn't mention parts or paint at all.
bonzoronnie
posted on 29/11/07 at 12:16 PM |
GRP Paint
Hi all.
I saw this stand at the Exeter Kit car show.
In my view. The finish of the car was total crap. ( Honest it was )
Yes It looks good in the photographs but it did not look the same at the show
I am not sure but I would imagine a good quality 2 pack acrylic paint would be best for painting GRP.
I am sure I'll be corrected if I am wrong.
Ronnie
bassett
posted on 29/11/07 at 12:41 PM |
Doesnt look too bad in the pictures but is a slightly hazy. If it looked better than gel coat and only £200 it could be worth while if you mearly
wanted a change of colour.
marcjagman
posted on 29/11/07 at 01:07 PM |
I found good old fashioned synthetic to give the best finish, and if you mix with about 15% 2K harderner the finish is glass like, dries quick and is
easy to t-cut/polish
house19uk
posted on 29/11/07 at 01:17 PM |
Have to agree with bonzoronnie the finish was total crap wouldnt want it on my car. They told me the only part of the body that was finished was the
rear wing and that was crap
twybrow
posted on 29/11/07 at 02:32 PM |
Why does no one consider using gelcoat. It is sprayable, it doesn't have the nasty volatiles as 2 pac systems tend to have and if you are an
amateur, they are forgivable and can be easily repaired!
James
posted on 29/11/07 at 02:47 PM |
Just ask Donut... it's fine for you to use just a roller and a can of household gloss!
Sorry Andy!
James
- Muhammad Ali
bonzoronnie
posted on 29/11/07 at 03:30 PM |
Gel coat
I may be wrong. But is'nt the gel coat sprayed directly into a mould prior to the laying up of the GRP mat.
As far as I know, gel coat is not applied after the product has left the mould.
I have seen boat yards using 2k epoxy resin for repair work.
I do stand to be corrected. I am a little out of touch with the most up to date finishing systems. Although I have kept my air-fed respirator &
filters up to date.
Ronnie
twybrow
posted on 29/11/07 at 05:19 PM |
Well you are correct, gelcoat is usually applied as the first layer to a female mould (well technically its actually called flowcoat, buts thats
another matter), however, it is just a layer, it can be put on before of after GRP work. Some hi-tech yacht manufacturers for instance, use male
moulds, ie they start at the inside of the hull, and work outwards. As such, the final layers would be gel coat.
Traditionally, it has been hand applied (with brush or roller) but there is nothing stopping you using it with a spray gun. You just need to be
conscious of the viscosity (ie it needs thinning with styrene or acetone) and the workable time (so as not to go-off in the spray gun).
Something like this:
A useful link with some spray settings and a run down of the prep needed...
http://www.boatdesign.net/forums/showthread.php?t=6328
I have seen a 65' £3million boat finished in exactly this way - and it looked beautiful afterwards!
[Edited on 29/11/07 by twybrow]
posted on 29/11/07 at 05:49 PM |
I thought gel coat did not cure properly if it was exposed to air?
bonzoronnie
posted on 29/11/07 at 05:50 PM |
I stand corrected
Hands up, I stand corrected
A good example you have posted.
I must say. I have seen some superb Yacht gel coat finishes here in the west country.
Ronnie
smart51
posted on 29/11/07 at 08:27 PM |
you add wax dissolved in styrene to it. The wax floats to the top, keeping the air out and it cures.
twybrow
posted on 29/11/07 at 09:32 PM |
smart51 goes to the top of the class. Alternatively you just let it cure as it wants to. leave if for at least a week, then sand the surface back, but
the wax route is much better.
RK
posted on 30/11/07 at 12:40 AM |
Where would one get the wax? I've looked around hardware stores and the like, and nobody knows what I'm talking about. Ditto for the yacht
supplies store.
2b_pablo
posted on 30/11/07 at 08:18 AM |
£200 would 2pack DIY paint a kitcar and thats inc buying a compressor.
[Edited on 30/11/07 by 2b_pablo]
smart51
posted on 30/11/07 at 08:22 AM |
CFSnet sell it, as do Scott Bader. You can buy wax in styrene separately or you can buy it premixed into the gel coat.
twybrow
posted on 30/11/07 at 10:17 AM |
You would need a GRP supplier - or a yacht repairer/industrial moulding company might sell you some.
Mave
posted on 30/11/07 at 07:13 PM |
I've painted my classic Mini (including GRP flipfront) with this paint, simply because I couldn't justify the 1000-4000 pounds quotations
I received from different paintshops.
I must say it is great stuff. And it works a treat. But, you will have to polish it to get a really good result. In my case there was quite some dust
in the paint....... But it flows really nice, and doesn't show brushmarks or rollermarks.
I'm pretty confident you can reach a really excellent finish, but you need to be prepared to invest quite some time.
Alex B
posted on 3/12/07 at 06:31 PM |
Glassplies in Southport for ALL glass stuff.
Alex
Much work still remains to be done before I can announce my total failure to make any progress
