wilkingj
posted on 3/12/07 at 08:25 AM |
Rover T series (In line gearbox bellhousing)
Does the team know if anyone makes a bellhousing for the Rover T series engines. ie so it can be made in line for a kit car.
Also, if there is one made, what gearbox it is for.
Having a silly idea about using a rover 220 Coupe engine. They are T series, Turbo'd, and easily make 200BHP.
A nice package, although I believe its quite a tall engine.
Best Regards
Geoff
http://www.v8viento.co.uk
Humbug
posted on 3/12/07 at 08:51 AM |
Robin hood used to do packages with T-series, gearbox and everything
Paul (Notts)
posted on 3/12/07 at 09:14 AM |
Dont know much about it but thid thread may help
http://forums.mg-rover.org/showthread.php?p=345737
Paul
Tangerine Scream
posted on 3/12/07 at 09:42 AM |
Look for the much maligned discovery MPi
Runs a NA T16 2 litre with an LT77 box.
It is quite tall but doesn't look that big in the disco engine bay ![](/images//smilies/bigsmile.gif)
Ricks-9r
posted on 3/12/07 at 10:49 AM |
Freelander also![](/images//smilies/wink.gif)
Fatboy Dave
posted on 3/12/07 at 11:17 AM |
Freelander is FWD and transverse so no use.
Bellhousing from Sherpa/LDV with 2.0 O series petrol engines or 2.0 diesel 200/Pilots is what you want. Disco input shaft is shorter IIRC so
bellhousing is not suitable.
I've T16ed a few Locosts as for stock power and cost they can't be beat. All turns to expensive nutsack when you try and tune them
though.
I have several bellhousings stashed as they're not exactly plentiful
Dave
Stop the planet, I want to get off
iank
posted on 3/12/07 at 11:35 AM |
It's also a bit heavy IIRC. PPC had an article on it a while back. One of the projects is to stuff one into an MGB using the original gearbox
Anonymous
oadamo
posted on 3/12/07 at 06:06 PM |
http://www.cosic.org.uk/MarkoStuff/Series%20Land%20Rover%20T16%20Turbo%20Conversion/
posted on 3/12/07 at 07:01 PM |
They used an MT75 with an adapter plate IIRC. Probably cut out with an axe by a blind man.
posted on 5/12/07 at 08:34 AM |
Freelander also
Not ever used in the Freelander
It is however a very very good engine even non-turbo MPi form it chucks out 140 bhp with really sweet power delivery.
[Edited on 5/12/07 by britishtrident]
Volvorsport
posted on 5/12/07 at 10:14 AM |
yeah the plate was plasma cut - the holes then punched out , by a blind man holding an axe .
its worth bypassing these , since they leak oil from new - had oiling issues aswell .
www.dbsmotorsport.co.uk
getting dirty under a bus
