DarrenW
posted on 31/1/08 at 10:32 AM |
Zetec or Duratec
I was chatting to a mate last night about speccing a kit and engine choices. 2.0 Duratec is the favoured engine choice but being quite new they seem
to be pricey still and not many have been fitted compared to zetecs etc. The reason for favouring duratec is the newness and the anticipation that in
the near future good power increases can be had for sensible money.
Reason for the post is therefore - what would you choose and why? (limited to 2.0 flavours please)
If you opt for duratec why would you do that and where would you look to source one at a decent price (and the bits to make them run in a se7en). How
would you fuel it - again on a reasonable budget? What gearbox would you opt for?
My view was that there are more parts for the zetec available off the shelf and if you pop an engine a replacement can be had farly cheaply, but im
sure in a couple of years the same will be said of duratecs.
Hopefully this will provoke an interesting debate.
I dont suppose anyone has a knackered bottom end they are willing to loan out do they so engine mounts etc can be made?
posted on 31/1/08 at 10:34 AM |
Duratec will need a different bellhousing as well, they are not the same pattern as the older Fords.
DarrenW
posted on 31/1/08 at 10:37 AM |
Yeah, we are aware of some of the basic differences. Not looked into wiring and fuelling specifics yet though. Things like bell housing adaptors are a
key consideration on cost.
novacaine
IIRC the duratec was a joint development between ford and mazda,
could that mean that there is a possibility of an mx-5 Gearbox bolting up ?
just a wild guess, but if it works, could be very useful....
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but
your older, shorter of breath and one day closer to death
Guinness
I'd go duratec. The fact that the zetec is an iron block and the duratec is alloy would be the deciding factor for me.
Mike
DarrenW
posted on 31/1/08 at 10:42 AM |
Interesting point Mike. Does anyone know the weight and dimension differences between the 2? Are duratec sumps easily modified? Any issues with
location of ancilliaries?
posted on 31/1/08 at 10:53 AM |
I'd favour the zetec. Bolts straight on, has exhaust on the correct side so deafens the passenger not driver, can get pre 95 flavour so no need
for cat so can be run on carbs.
bassett
posted on 31/1/08 at 11:12 AM |
Id go zetec as at the moment there cheap and tuneable and then in a few years go for the duratec once the prices are reasonable and a few are knocking
around. Surely the change wouldnt be that expensive and only a few mods would be needed when you need to make the change. What fords come with the
duratecs fitted?
bob
posted on 31/1/08 at 11:14 AM |
Just seen this duratec bolted to what looks like a type 9 with modified ali bellhouse.
Might be the picture but that engine looks mighty big
![](/galpreviews/a684924-00034.jpg) ![Rescued attachment 00034.jpg](/gallery/a684924-00034.jpg) Rescued attachment 00034.jpg
bob
posted on 31/1/08 at 11:17 AM |
I should have read more its a BGH type 9, nice site.
linky
Fatboy Dave
posted on 31/1/08 at 11:46 AM |
The MX5 and Mazda 6 make RWD Duratec boxes available (six speed is also available).
Duratecs have been fitted to Mondeos since 2001 now so prices are timbling if you know where to look. It was the same with the Zetec though, it took
nearly ten years for the Zetec to be a viable 'pocket money' donor engine; the Duratec s a natural progression but with the added blow
that as noted there is no 'cheap' box like the type 9 that bolts straight on.
Dave
Stop the planet, I want to get off
posted on 31/1/08 at 12:01 PM |
Duratec engines are all alloy, very light, have a big valve head on them and breath a lot better than a zetec (or anything else before that) They
have a longer stroke and all this helps remissions in the Ford car.
A gearbox from an MX5 will fit OK so cheap forward for a 6 speed gearbox![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
The Duratec will take over the zetec the same way it took over the Pinto once there is plenty about and they get cheap enough. An exhaust, throttle
body's and cams should see the engine go near 300bhp.
Currently there's a series about installing one into an old RWD Ford in ClassicFord.
flak monkey
posted on 31/1/08 at 12:34 PM |
I would go for duratec, coozers listed all the important differences. they are a lot lighter than a 2 litre zetec.
Plus you can bolt on a throttle body kit and get 240bhp without needing to make any internal mods.
if I had had the money, I would have fitted a duratec from the start!
Sera
http://www.motosera.com
lsdweb
posted on 31/1/08 at 01:02 PM |
Try looking at Burton Power's summary of both engines -
Duratec
Zetec
This dispels some of the myths!
Westfield World have an intersesting comparison page.
I've been looking at this very thing and decided on a Zetec, based on cost. But, I'm having serious doubts all the time!
Wyn
thepest
posted on 31/1/08 at 01:28 PM |
Hey guys you're getting me drooling over these engines.
Fitting into a locost seems like and easy job, but I've been having another thought.
How about fitting one into my MR2? I was thinking of using it as a replacement of my 3s-GE engine.
Being a FWD setup since it is mid engine. Anyone done anything similar?
If I were to spend money on a 3S-GTE, this does seem like a bette alternative.
Does anyone know if any of the Ford FWD gearboxes come with LSD?
twybrow
posted on 31/1/08 at 01:30 PM |
Deffo Duratec for me. More modern, more efficient, lighter. Downsides - less cheap parts, more mods needed to fit RWD (water rail, alternator etc),
awkward exhaust.
They have come in price a stack load in recent months. Check out
this one on ebay...
onzarob
posted on 31/1/08 at 02:57 PM |
Thats a great bit of news, MX5 gearbox go for about £70 on ebay
I suppose a prop to a sierra diff would be the easiest solution?
Mole
posted on 31/1/08 at 03:04 PM |
I have a zetec and I don't regret the choice given my circumstances but if I had the money it would be the Duratec.
muzchap
posted on 31/1/08 at 03:55 PM |
Bolting on Throttle Bodies gives 240hp!
That is complete BOL**X!!!
I'll challenge you now to show me a Duratec (standard) making 240hp with Throttle Bodies!
My Honda S2000 engine makes only slightly more than that with millions of pounds worth of development by Honda!
It's this kind of USELESS information that causes people to become dissapointed.
A stock Duratec on TB's - is likely to make anywhere between 150-185hp - and you'd have to be fkin lucky to get it up there. If you spent
money on Roller Throttle Bodies and some internal work - you can make 200hp ish
Honestly - 240hp!
I suppose my Honda S2000 with some bike carbs will make 500hp by that logic!
**RANT OVER**
ZETEC
+ cheap, reliable, parts easily available
- heavy (ish)
DURATEC
+ Light, tuning potential
- expensive, expensive to tune, expensive ancilieries
Also - depends on which side you want the ZORST
Zetec = passenger
Duratec = driver
P.S - I was under the impression that only 'new' MX5 gearboxes fit? Not the old ones - unlikely to get a new MX5 gearbox for £70!
[Edited on 31/1/08 by muzchap]
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
lsdweb
posted on 31/1/08 at 05:22 PM |
Quoting Burton Power -
'What this means to us is it doesn’t take much to tune the Duratec to around 200bhp, at which point, you need to switch the rods and pistons to
more reliable components. '
[Edited on 31/1/08 by lsdweb]
lsdweb
posted on 31/1/08 at 05:34 PM |
And Shawspeed - 230BHP with ECU, TB's, cams etc....
flak monkey
posted on 31/1/08 at 05:54 PM |
My bad, 190bhp with no internal mods. Then if you want 225bhp its a new cams job.
http://www.webcon.co.uk/alpha/AlphaPlusKits.htm
K3220JR Gold Kit - Ford Duratec 2.0 (OE T/Body) - 220BHP £895.00
http://www.webcon.co.uk/alpha/Duratec%20JR%20Flyer%20Ver1.pdf
[Edited on 31/1/08 by flak monkey]
Sera
keith2lp
posted on 31/1/08 at 06:43 PM |
Duratec
I am just coming to the end of a Duratec install upgrading from Pinto and to be honest it is no more difficult than putting in a Pinto/Zetec or Bike
Engine.
Yes the costs can be expensive but it depends on how far you want to go with making your own parts etc. A water rail is not required (look at
westfields installation) the alternator is no more difficult to do than a Zetec just use a small denso one and make some mounts and use a belt from a
Mazda 3 Sport.
The oil filter does need a new outlet to turn it thru 90 degrees but on a new build you could make the chassis to suit the original. I think the
original sump could be baffled if required.
The exhaust is no more of a problem than any other engine, I have managed to rework my Pinto one to suit a new flange.
The clutch need to be hydraulic and this costs about £120 to do and a new bell housing will be required if you use a type 9 box.
The induction side can be T/B or a manifold for twin webers is avaliable for about £80.
I think my total cost after selling the pinto parts will be about £1800 but I will have a lightweight package giving 185-200bhp from a standard engine
that will last the life of the car.
The only down side is that it is quite a tall engine (about 25mm less than a Pinto) but if you have a pinto in the first place that wont be a
problem.
I will post some photo's later.
[Edited on 31/1/08 by keith2lp]
zetec
posted on 31/1/08 at 06:56 PM |
I was thinking of swapping to a Duratec but after talking to Dunnels it looked a better move to go for cams for the Zetec , and get a little more
power than a standard Duratec running like for like on TBs.
The Duratec would be a nice choice but do your sums first and take into account gearbox etc.
I've just stripped two zetecs, one with 122K and the other with 70K miles and both were still like new inside...
Don't get too hung up on peak power as things like gear ratios and torque will made the big differences.
[Edited on 31/1/08 by zetec]
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
posted on 31/1/08 at 07:22 PM |
Go for it - who says they are expensive engines??
Bargain:
http://cgi.ebay.co.uk/DURATEC-2-0_W0QQitemZ320213062172QQihZ011QQcategoryZ21654QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
