skidude88
posted on 20/4/08 at 07:03 PM |
Master cylinder reservoir
Was hoping to remote mount a reservoir as the steering column UJ is hitting it.
Thought it would be an easy job....
....Typically my M/C doesn't look as though it will be easy to do?
I've tried to ID what its off on BrakesInt - closest I can find is Capri? (ran out of viewings)
I can't actually get the reservoir off, I assumed the end that wasn't screwed in was push fit....I can lift the car up it's in so
tight!!!
I've tried winding in case there's a thread, also reverse in case it's left handed.
Can't get the damn thing off & don't wanna bust it.
So taken the whole lot out
Could someone confirm or not if it is pushed in before I get medieval on it?
Also has anyone got any tips if they have remotely mounted this particular type of M/C.
1st Pic is of the M/C with the reservoir rotated out of the way.
![](/galpreviews/master front_s.jpg) ![Original master cylinder front](/gallery/master front_s.jpg) Original master cylinder front
![](/galpreviews/master_s.jpg) ![Original Master cylinder](/gallery/master_s.jpg) Original Master cylinder
James.
![](/galpreviews/mc-reservoir_s.jpg) ![Original mc+res](/gallery/mc-reservoir_s.jpg) Original mc+res
[Edited on 20/4/08 by skidude88]
Early MK de-Dion CBR1000 FJ-FP.
Blakey_boy
posted on 20/4/08 at 07:45 PM |
If it is a Capri and it looks like it is then you can't put a remote res on it as far as i can tell you may be able to convert a Sierra M/C but
not the one you have as it is too old.
Disclaimer blah blah blah if i am wrong then tell me pleae but info given to the bes of my knowledge
Gene Hunt:- If anything happens to that car, I'm coming round your house and stomping on your toys, Understand?
