Blakey_boy
posted on 25/4/08 at 10:31 AM |
Seized calipers???? HELP
I am trying to refurb a set of M16 calipers and the pistons will not come out. I have the kit from Big red but, pistons only come part way out am I
missing something or not
Any suggestions
Gene Hunt:- If anything happens to that car, I'm coming round your house and stomping on your toys, Understand?
posted on 25/4/08 at 10:57 AM |
what are you doing to get them out?
I managed to get one piston out usng screw drivers to lever it out against the recess - very time consuming.
the sensible and clean but not necessarily safest way is to use compressed air or just connect back to hydraulic system and press the pedal.
you need to clamp one piston otherwise you find both may move but not sufficiently to pop either one out.
posted on 25/4/08 at 12:25 PM |
You need to make a clamp to hold one piston in while you pump the other one out. Fit seals in one side of the caliper then repeat for the other.
[Edited on 25/4/08 by britishtrident]
Blakey_boy
posted on 25/4/08 at 12:27 PM |
As I got them off a scrapper then I think I may have a few problems getting them out
Blakey_boy
posted on 25/4/08 at 04:09 PM |
Thanks for the help guys
got them all out cleaned and refurbished with new seals and dust cover and a lick of paint as well. Nice one
big_wasa
posted on 25/4/08 at 07:36 PM |
blow some air into them. 150 psi should do it
Tip put a piece of wood inbetween the pistons and keep your fingers well clear.
When they pop they will pop ![](/images//smilies/tongue.gif)
Blakey_boy
posted on 27/4/08 at 12:58 PM |
Thanks man
Already done reassembled and painted thanks to an earlier tip using screwdrivers
