oldtimer
posted on 18/6/08 at 05:25 PM |
Type 9 gearbox to bellhousing bolts, removal?!
OK, so I may be being a bit dim, but, when removing the bellhousing from a type 9, 3 bold heads are exposed and one is under the clutch arm, how do I
get to it??!!...........................
BearingKits
posted on 18/6/08 at 05:33 PM |
Knock out the peg and the clutch arm will come off.
www.Bearingkits.co.uk
Gearbox, Differential and Axle rebuild parts.
posted on 18/6/08 at 06:29 PM |
No need to knock out the peg just pull off the bearing and pull the arm towards the cable side of the bell housing
