pewe
posted on 29/8/08 at 08:35 AM |
SVA fail.....
Went to Southampton yesterday.
As prev. mentioned Mark there is a top bloke - helpful, efficient and gives it a very thorough going-over.
Fail was all self-induced (aren't they all?) - main ones - 1) HC level was way out, think I must have slipped a tooth on one of the cam pulleys
when I replaced the belt and 2) the rears locked before the fronts (some numpty put the larger m/c to the back) so hopefully both easily fixed.
Other detail ones for those going for SVA - No self adhesive pads to retain wiring (the Maplin ones really don't last).
No raw sheet metal anywhere they are likely to be contacted whilst the car is being serviced/worked on.
Edges on Racetech centre mirror and the underside of rear number plate light too sharp.
Interior switches and knobs must not project more than 9mm from the dashboard in the contact zone.
There were a couple of other points (anyone got a Sierra lower steering column for sale?) but again not too difficult to fix.
Altogether a good day out and not a drastic fail.
Next time I reckon I'll drive it there.
Finally thanks to all you guys on here for your help, advice and shared knowledge - it certainly made the difference.
Cheers, Pewe ![](/images//smilies/cool.gif)
richardh
posted on 29/8/08 at 08:42 AM |
lucky you didn't drive it there with the brake the wrong way round.. could have been interesting.
my racetech mirror went thro ok.
all in all not bad as you say. some easy bits to fix and hey presto!
pewe
posted on 29/8/08 at 08:52 AM |
Re brake balance .... yes especially as it was raining on the way down.
Serious point made by the examiner was that if he fails it for something major like brakes you won't be allowed to drive it home. Makes the £58
to Indespension for trailer hire look like money well spent.
Cheers, Pewe
PS they are all a great bunch of guys down there. During the course of the day I think what must have been all the examiners drifted by to have a look
and chat - word must have got out there was a supercharged kit downstairs!
[Edited on 29/8/08 by pewe]
ecosse
posted on 29/8/08 at 09:13 AM |
Bad news on the fail next one should be a breeze though?
Alex
PS
I just had a look in your photo archive, that is a top job fitting that engine in there ![](/images//smilies/cool.gif)
Guinness
posted on 29/8/08 at 09:44 AM |
Hi Pewe
Sorry to hear you failed. Most of them sound like fairly easy fixes, good luck with the re-test.
One thing did surprise me though was this:-
Sounds like they are taking the radius thing a bit far. I mean I can see why, but it's going to make some builds much harder. I thought
skinned knuckles where compulsory when servicing kit cars, and tin tops.
My Seat Leon has some REALLY sharp brake disc back plates, and nearly every time I clean the wheels I cut my hand on one of them!
Mike
saigonij
posted on 29/8/08 at 11:02 AM |
RE - larger master cylinder to the rear - thats the way its meant to be.
0.7 goes to rear, 0.625 goes to front.
0.625 produces more hydralic pressure than the 0.7 one, hence why its to the front.
If you swap them over, it will make the situation worse.
wilkingj
posted on 29/8/08 at 11:04 AM |
Sounds like a reasonable fail. All easily fixed.
You could drill through the adhesive tab and put a pop rivet in.
This is the whole point of a SVA, to make sure its built to meet the regulations.
Its in everyones interest.
Still... wont be long before its on the road.
Now... When you do get it on the road... TAKE IT EASY untill you have learnt how your car drives, and its limitations. We have already had one car
smashed recently.
Take care especially if its damp, greasy or wet conditions. Dont add to the statistics.
Finally Well Done for getting this far. Almost at the winning line now!!
Best Regards
Geoff
http://www.v8viento.co.uk
posted on 29/8/08 at 11:09 AM |
smashed recently.
Hmm, I concur with the above about taking it easy!![](/images//smilies/bigsmile.gif)
RoadkillUK
posted on 29/8/08 at 12:53 PM |
Not a bad fail really.
Regarding the Maplin sticky wire fixers, mine are still on 5 years after SVA, inside the engine bay too, even survived several pressure washes. Odd
folk at the DVLA
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
Stu16v
posted on 29/8/08 at 08:33 PM |
quote: Originally posted by saigonij
Correct...
