Jesus-Ninja
posted on 22/9/08 at 12:26 PM |
Bungs for the ends of 1" square tube
Do these exist? It strikes me that there are places where I have an open ended tube exposed. Are there a plastic bung for these, or shoudl I weld a
little plate over the end?
Suspension geometry tool here >>> http://www.locostbuilders.co.uk/viewthread.php?tid=81376
posted on 22/9/08 at 12:30 PM |
you can get them - look on the legs of metal frame tables like a school
As you can (we've seen you metalwork skills) I'd be empted to weld shut with small plates. The end result will look better much better
IMHO.
grassracer
Towsure...try a google search
martyn_16v
posted on 22/9/08 at 12:42 PM |
I got half a dozen or so off ebay for a few quid. Probably would be able to find them cheaper somewhere else, maybe a big B&Q.
philhoward
posted on 22/9/08 at 12:44 PM |
Try Moss Plastic parts at
Linky
I have about 300 off that have a OD of 22mm square and fit a hole approx 19mm sq. Let me know if these are of interest. You can have them for 20p each
(cost price)+ P & P
smart51
posted on 22/9/08 at 12:50 PM |
I've got a bag full of plasting bungs for 1" square tube. Do you want some?
Personally, I'd weld over the end of any tubes. Salt water from the road will probably find its way around the bungs.
ecosse
posted on 22/9/08 at 01:09 PM |
I welded mine, for the reasons already given (and also because I couldn't find any flush fitting plastic ones! )
Alex
posted on 22/9/08 at 02:58 PM |
see:
http://www.locostbuilders.co.uk/viewthread.php?tid=93983
RoadkillUK
posted on 22/9/08 at 03:03 PM |
This place does them, just phone 'em as they don't do online ordering.
It's just over the road from me too.
I've used them on the bottom of my fish tank stand that I made, but on the Locost the ends are closed with welded plate.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
RoadkillUK
posted on 24/9/08 at 11:11 AM |
Ok, I'll put the link up then
Bradford Rubber
Roadkill - Lee
www.bradford7.co.uk
locost westie
posted on 24/9/08 at 05:07 PM |
I can remember seeing these on counter at Eggleston bros in Derby, maybe other steel stock holders have them.
Doug68
posted on 24/9/08 at 10:52 PM |
I took some bolt cutters to 1" strip to cut the tube end plates. A good bit quicker and less agro than hacksawing a bunch of these things.
Doug. 1TG
Sports Car Builders WA
Nisseven
posted on 2/10/08 at 09:48 AM |
Weld them up. If nothing else it makes the tube stronger.
Bruce
Alan B
posted on 2/10/08 at 11:54 AM |
Another thing worth pointing out is that sometimes you can make the endcaps do double duty.....e.g. extending them and putting a hole in to mount
something, or if at a corner extending the sides and make it into a triangle to serve as a gusset.....
Just a thought...
Colin would be proud of you..![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
posted on 2/10/08 at 12:06 PM |
I welded the ends of mine.
Cut out squares from 1.6mm sheet to be a loose fit in the ends, held them in place with a small magnet and tack-welded, then removed the magnet and
finished the welding. After cleaning up with a flap wheel in an angry grinder it looks like a solid piece of metal.
[Edited on 2/10/08 by David Jenkins]
MakeEverything
posted on 12/10/08 at 02:11 AM |
Or some 25mm flat bar cut into 25mm squares. A Local machine shop should be able to guillotine these for you out of 16g or even 8g for the use that
Alan B says above.
Kindest Regards,
Richard.
wment
posted on 10/3/09 at 11:16 PM |
On a ladder type chassis that went all the way from front to back I filled the entire tube with aersol foam called Great Stuff here in the US. It is
expandable and works best when its warm. It keeps everything out of the tube.
posted on 11/3/09 at 09:29 AM |
Sounds like the stuff Alfa Romeo used to put in the sills of Alfa Suds. They were famous for turning into a pile of brown dust almost overnight ![](/images//smilies/bigsmile.gif)
40inches
posted on 13/3/09 at 12:59 PM |
Just bought some off eBay, look up item no:250383807445 £2 for 8, not cheap but how many do you need?
Blackbird
posted on 13/3/09 at 04:17 PM |
I cut my tubes with integrated end caps so when it's all welded and smoothed out you can't tell which side was open.
Moti
[Edited on 13/3/09 by Blackbird]
![](/galpreviews/a906105-IMG_1651w.jpg) ![Rescued attachment IMG_1651w.jpg](/gallery/a906105-IMG_1651w.jpg) Rescued attachment IMG_1651w.jpg
A wise man said - don't count your years, make your years count!
Or was it beers?
Either way, it's a pretty good advice.
